Excerciser was set to run weekly and was working, then 1 week generator ran 30 seconds and turned off, next week it didn't run
SOURCE: Generac Generator won't stay running
fuel problem, the float in the carborator is stuck, if you tap on the carborator bowl it will probably get freed up.if not take the bowl off and spray the insides with carb. cleaner.
SOURCE: Generac 43903 standby Generator overspeed indicator on starting
I have a generator that did the same thing. It would start and then stop within a few seconds. The more expensive generators have an oil level safety switch to prevent the engine from burning up. There is usually a wire connecting to the switch on the outside of the engine near the oil fill hole. Remove this wire and try to start the generator. If it runs without a problem then it is the switch. You need to remove the switch and take it apart carefully and clean it. There is a small float inside the assembly. When the oil runs low the float allows the switch to short to ground which kills the spark to the spark plug. Hope that helps.
Bob Janelli
I’m happy to help further over the phone at https://www.6ya.com/expert/bob_62dfa2f81bb55288
Testimonial: "This is good information in the event that the low oil switch is part of the problem."
I had this same issue with my NP 50G. I replaced the oil pressure & over heat sensor and fuel filter but the problem still existed.
After that I took the fuel bowel off the carb which had some dirt in it. Sprayed it with carb cleaner and that solved the issue. Hope this helps......
SOURCE: I have a new Kohler 12kw res generator on propane - backfiring
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
