Question about The Computers & Internet
I just got my tablet an I use it for music when I wish dishies an no water goes on it an I went up stairs an I didn't hear no sound an it not on mute or the volume not down I don't know what to do.
  • Gep Pep Apr 19, 2019
    Hi Jeralmiah Mccormick, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What tablet? Earphones on cord or speakers or Bluetooth headphones?
SOURCE:
kefy
SOURCE: disabling the mute in the music player
sometimes a gadget just gets confused and restoring factory settings can fix that problem. Go to menu-tools-settings-general-factory settings the phone asks Restor original settings phone will restart press yes it asks for security code. The default code for nokia is 12345. If this doesnt work enter this code *#7370# and the phone will reset. You then set it up as new
Posted on Jul 24, 2007
SOURCE: nokia n95 volume button goes
remove battery .take off outer cover (as seen on you tube)locate suspect button which has 4 soldered tabs.on my phone the solder on the outer 2 tabs had parted from the board use a small ended soldering iron (or in my case a bit copper wire from a scrap of coax cable wound a few times around the tip trim off to leave about 4mm protruding} gently with a little lever on top of the switch (I used a 1mm drill bit a matchstick might do }close it down onto the board,tin the tip of the iron hold it on one of the tabs for about 10 seconds keep the gentle pressure on the lever for a few seconds after removing the iron repeat on other tabs.
If the button is completely off or you can't manage the soldering,hold the battery in place switch on phone play a tune in music player get a pin touch it across the 2 bottomtabs and you will see the volume rise each time you touch.Leave it on preferred setting.The camera zoom can be reset by simply shutting and opening the shutter each time'"have fun"
Posted on Nov 27, 2008
tubby20076
SOURCE: my ipod 5th gen 30gig has no sound. if you turn
Since May 2009, Apple are providing after-warranty replacements on the 5th Generation Video iPods, with the "no sound" issue - due to it being a manufacturing error/defect rather than a hardware issue (hence why the warranty etc doesn't matter)
http://discussions.apple.com/thread.jspa?threadID=1095417&start=360&tstart=0
There is the popular link at Apple support forums.
Posted on Jul 20, 2009
SOURCE: No sound dell Inspiron 8200
If your touch pad doesn't work too, there is a connector under the keyboard that affects both the sound and touch pad. It may have come disconnected.
Posted on Oct 25, 2009
SOURCE: my volume meter disappeared. I went to control
Follow this path:
Start >> All Programs >> Accessories >> Entertainment >> Volume Control
See if you get the Volume control or not. If you are able to get the Sound properly then you can create a Shortcut of Volume Control from the same path whihc i given...
Posted on May 04, 2010
My evotel tv wont come off mute(even though it says mute is off )
Sounds like fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 27, 2014 | Televison & Video
My tablet is on mute for call also cant play music
Well, turn up the damned volume. Is that so hard to work out?
Aug 17, 2014 | Tablets & eReaders
My tablet is on mute for call also cant play music what maybe the problem?
Well, turn up the damned volume. Is that so hard to work out?..
I an having problems unmuting my phone at times, it just goes on mute automaticly, i can hear them but they cant hear me
Does it show an icon, usually a crossed-out microphone, informing you that the call is muted? Or people just can't hear you?
You may have a broken microphone in the phone, it happens.
Mar 20, 2014 | Samsung Galaxy BBSPHP1 Tablet PC
My Sony Vaio VGN-FS690P has stopped playing sound. The sound card states it is working correctly. It does play one sounds, the sound when it starts and show the VAIO screen.
Hopefully this helps. Right click on your volume control icon. Open the "Volume Mixer," and make sure that nothing has the mute X on. Then right click on "Volume Control," and make sure that the volume control is checked to play all sounds, and that your Speaker box is checked. Next step is your music, if the sound was muted directly @ the music playback, this could be the problem. Open your Media Player and try to play music, if you cannot hear it, click on the mute button to the song playing. If your Player was shut off in the "mute" mode, then you will not hear sound. It Happened to me once. You will need to check all of your "Players" to see if any of them were shut off in "mute."
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Sep 26, 2010 | Sony VAIO VGN-FS690P Notebook
My Speakers On My Computer Wont Work But I Can Hear A Buzz Sound?
1st of all click on start->programs-> Accessories->Entertainment->Volume control->options->properties->select Microphone->then click on Mute on microphone. hope this will work
Jun 07, 2009 | Computers & Internet
Sound problem
Has the audio output been muted? Check for that.
Sep 06, 2017 | Gateway M275 Tablet PC
Mute Button (touchpad)
This could be a simple driver glitch. Try uninstalling the audio drivers from the device manager, then reboot. The machine will find he sound card and reinstall the drivers automatically. Then go to HP's support site and check for any updated sound drivers or patches. If it's a glitch this will fix it. Keep in mind that it could also be a hardware problem with the mute switch, so if the driver procedure doesn't work, you might consider having it serviced.
Sep 03, 2008 | Computers & Internet
AEG Favourit 446
Our AEG dishie also tripped the light regularly. Turned out there was a water leak by the motors and the cut off device wasn't working and when the water filled up too much it tripped. Move the dishie and if water 'sloshes' out the back, then you know the problem, or if not, take the side panels off so you can see underneath, if there is water at the bottom of the machine. Hope you find the problem.
Aug 11, 2008 | AEG 24 in. Favorit 40310 Free-standing...
Sound
install motherboard software den restart your pc, tnx
Apr 17, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
13 people viewed this question
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Inky Fingers
Inky Fingers
Fred Sops
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
