SOURCE: Printing labels on Ricoh 1224C copier
Labels should only be printed through the bypass tray. when printing, go to "properties", "Paper" and change tray from "auto select" to "Bypass tray"
SOURCE: Smart Label Printer 240
Check your labels. Are there black "sensor marks" on the back of each label? That's apparently how the printer lines itself up.
SOURCE: An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
SOURCE: 2844 UPS Printer Prints Duplicate Labels
The quick and simple answer is to use a different driver instead of the 2488 driver that UPS provides, that is where the problem lies..
Under printer properties, Advanced Tab, I changed the printer driver to Zebra S4MDT-200dpi and now the printer works fine. Prints labels correctly, and most of all only one label at a time... The drivers are there in the UPS software, just change which one you use and go...
John Plemons
SOURCE: I have a Smart Label 100 printer that won't print.
WHEN THIS HAPPENED TO ME, I DELETED THE PRINTED AND REINSTALLED IT...
