Question about Frigidaire Washing Machines
What is the capacity of Frigidaire washer GLTF1240A
    Scholar:
  • 63 Answers
The Frigidaire GLTF1240A clothes washer has a tub capacity of 2.65 cubic feet. Under typical conditions, based on a yearly average of 392 loads of laundry, the Frigidaire GLTF1240A is estimated to use 341 kilowatts of energy per year. Obviously, this number will vary depending on things like the size of loads that you wash, and temperature at which you wash your clothes. Also, this figure is calculated according to a test done by the US Department of Energy which takes into account the energy consumed by the washer as well as the energy needed to heat the water with an electric water heater. If you use a gas water heater you will probably use fewer kilowatt hours but you will consume gas to heat the water.
Its estimated water use is 9,806 of gallons per year. It is estimated to use 9.4 gallons per cycle, per cubic foot of tub volume. You can use this "per cycle, per cubic foot" to compare washers against each other. The lower the number, the more efficiently the washing machine uses water, assuming your clothes are equally clean after being washed in either washing machine.
Posted on Apr 16, 2019
  • iain thomson Apr 16, 2019
  • adrian Brody
    adrian Brody May 08, 2019
    Customer helpline phone number is +1 8OO 648 162O
    Problem Solver:
  • 8 Answers
Conatct customer help,line phone number is +1 8OO 648 162O ,,.....
Posted on May 08, 2019
2 Suggested Answers
SOURCE:
  • 7 Answers
SOURCE: What is Cubic Ft Capacity of Washer?
It's in the model number, and it's 4.4 cft. Which is one of the largest capacity washers available.
Posted on May 27, 2009
The fabric softner tray isn't draining
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Feb 21, 2011 | Frigidaire GLTF1240A Front Load Washer
LOOSE DRUM, BANGING
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 25, 2010 | Frigidaire GLTF1240A Front Load Washer
Water under washing machine
well u definitly have a leak may be just a hose or a pump problem u need to flip it over to check where the leak is then post again
Oct 28, 2009 | Frigidaire GLTF1240A Front Load Washer
Washer will not go into fast spin cycle
SOUNDS LIKE YOU MAY HAVE TTO REPLACE YOUR BELT ON YOUR WASHER. I AM NOT A MECHANIC, BUT I THINK THIS WILL HELP.
May 13, 2009 | Frigidaire Washing Machines
Water leak from front load washer - Frigidare GLTF1240A
just remove bolts, open bit enough to fill with silicone, close back wait to dry, ready to go for couple more years.
Apr 25, 2009 | Frigidaire GLTF1240A Front Load Washer
Blinking lights and failure to start
Suggestion: 1 Press and hold down 'spin' & 'dry' buttons to unlock controls. 2 Have u overloaded the machine with clothes? Reduce load. 3 Try 'spin' only after putting the clothes. Then put off machine & continue with main cycle. Three suggestions here........ What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Feb 07, 2007 | Frigidaire GLTF1240A Front Load Washer
Washing Machines Logo
232 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
