SOURCE: loss of suction and bag full
Sounds like you still have a clog, either in the hose, drop something down it to see if it comes out the other side. The other place is the dirt inlet by the brush roll. Take off either the top cover or the bottom plate and you can check it out.
SOURCE: Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
