I printed using a 10.5x33cm-sized paper. The printer took much longer to pull each paper in. It has around 5 second interval after each paper finishes being printed. It works normally if I use common size paper like A4 or F4 (which is twice the size of the custom size paper I used). Any suggestion on this issue?
Carefully clean the rubber rollers and paper path with Isopropyl Alcohol then try it again.
Testimonial: "Why do you think it has sth to do with the rollers. It works normally with F4/A4 paper. The slowing down only happens when I use a 10.5x33cm paper size (which is half of the F4 paper cut vertically)."
It's usually the printer cleaning the print head
SOURCE: "always getting check paper size"
the sensor flag at the rear paper path sensor is worn down too short. i have seen this many times
SOURCE: Printing Business Cards on Cardstock
Yes, the roller system will only open wide enough for semi thick cardstock. If you read through you're manual you'll find the recommended card stock you can use. HP supports HP paper.
Here is a list of supported HP paper.
http://h10025.www1.hp.com/ewfrf/wc/prodTopCategory?product=16118&lc=en&cc=us&dlc=en&dest_page=product
See the user manual on page 45.
Papers to avoid when printing
It would not hurt to remove the rear door & clean the rollers. (No soap). Dried soap film will cause paper to stick to the rollers. You can go to Wallmart or a local hardware store & buy a bottle of Grease Lighting. This heavy duty cleaner (When dry), does not leave any soap film. Great for cleaning just about anything.
If you wish to download the user manual from HP (It's easer to see & find information faster. Just click on this link:
http://h10032.www1.hp.com/ctg/Manual/c00461378.pdf
Good Luck!
Mike
SOURCE: Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
SOURCE: printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
SOURCE: how to print a custom size paper on HP Laserjet
USe the Page Setup in the word processor. It is how the word processor uses the printer that matters. There you will find Custom and you can specify the page size.
Testimonial: "Thank you for the advice!"
Selecting which tray is used for printing
You can select how the printer pulls paper from the trays.
Understanding tray order
When the printer receives a print job, it selects the tray by trying to match the requested paper
type and size with what has been loaded in the trays. Using an "autoselect" process, it searches
all available trays for the paper that satisfies the request, starting with the bottom tray and ending
with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/
size.
Note The "autoselect" process occurs only if no specific tray is requested for the job. If a specific tray
is requested, the job prints from the requested tray.
If paper is loaded in tray 1 and tray 1 is set TRAY 1 TYPE=ANY and TRAY 1 SIZE=ANY on the
Paper Handling menu, the printer will always pull paper from tray 1 first. See "Customizing
tray 1 operation" on page 47 for more information.
If the search fails, a message appears on the printer control panel display requesting that
you load the correct paper type/size. You can load that paper type/size, or you can override
the request by selecting a different type/size at the printer control panel.
If a tray runs out of paper during a print job, the printer automatically switches to any tray that
contains the same paper type/size.
The autoselect process changes somewhat if you customize tray 1 operation (as explained in
"Customizing tray 1 operation" on page 47) or set tray 1 for manual feed (as explained in
"Manually feeding paper from tray 1" on page 49). See if this works. Good luck !
