Question about Crock Pots & Slow Cookers
Cooker ignites but doesnt stay on when button is released
    Top Expert:
  • Crock Pots &... Master
  • 63,068 Answers
BAD THERMOCOUPLE WILL CAUSE THAT
Posted on Apr 15, 2019
SOURCE:
When plugged in programmable timer blinks error
I don't know if this will work for you, but...
if the slow cooker has buttons that you push to program it, press and hold the buttons down while you plug the slow cooker in. Hold them down for a long count of 10 and then release them. It might reset the logic inside. Good Luck
Feb 26, 2010 | Crock Pots & Slow Cookers
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
I can't set my slow cooker to high
If the slow cooker will not change the display from 0 to 1 to 2 to 3 etc. when you press the "COOK TIME" button, then unplug the slow cooker. Hold both the COOK TIME and the ON/OFF buttons down and plug the slow cooker into the wall. Keep both buttons held in for a count of 10 then release them. The slow cooker should work correctly now.
Dec 30, 2009 | CorningWare SC60 Slow Cooker
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
Can't change temperature-stays on "warm"
Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
May 19, 2009 | CorningWare SC60 Slow Cooker
I try to set the time and temp and just keeps blinking
try to push and hold after you set the time and/or temp until it flashes the appropriate setting then stays solid
if there is a menu button.... time, hour... press till the right hour is on, min.... til the right min is on then menu or ok and either release or hold....
basiclly a process of elimination.
not sure if it will solve your issue. just giving you another option to try.
also unplug and wait 10 sec to let the slow cooker reset before you try again
let me know at sparkallen@aol.com
Dec 25, 2008 | GE Crock Pots & Slow Cookers
Can't go straight to warm setting
Hi, Guys,
I discovered this solution by accident. To get my crock pot to go to the "Warm" setting directly, I begin by pressing and holding the "Cook Time" button. Then, with the cook time button held down, press and release the "Off" button, holding it down for a second or so and then releasing it. Finally, lift your finger off the "Cook Time" button. Presto! The unit will be set on "Warm." So the key to this is to press and release the "Off" button WHILE the "Cook Time" button is being held down. Might take a couple tries before you get it, but then you'll see that it works every time.
Jan 27, 2008 | Rival 38501 Smart Pot 5-Quart
Rival 38601 Smart Pot 6-Quart Slow Cooker can't get to to go to warm
Here is the manual for this cooker; http://www.crockpot.com/manuals/38601-C_English.pdf page E4 and E5 tells you details of programming/timer/temperature. Check through everything and see if you can figure anything out. after cooking, the unit should automatically switch to warm mode, if it isn't doing this then unfortunately i think it needs a replacement control board - probably not worth doing. If you want to give it a try then post again and we can try and source you the bits Hope this helps :)
Mar 16, 2007 | Rival 38601 Smart Pot 6-Quart
Crock Pots & Slow Cookers Logo
27 people viewed this question
Top Crock Pots & Slow Cookers Experts
ellenskitche
Irene Tulloch
Marvin
Marvin
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
