Question about Radio Communications
Can you forward to me the manual that will instruct me how to program freqs into my pro-2026 scanner? gerald
  • Radio Commun... Master
  • 26,838 Answers
SOURCE:
mixmaster
  • 626 Answers
SOURCE: radio shack pro 2038
User Manuals are here;
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=20-413&Name=Radio%20Scanners&Reuse=N
Best of Luck.
Posted on Nov 15, 2007
oldnovii
  • 667 Answers
SOURCE: Owner's/Instruction Manual
Hi SDGirl - This is a slightly older model and there's not much out there. You won't find one at Tandy or Radio Shack Sites. I'll give you a link where you can find it ( sort of) in sections. I believe it will tell you everything you need to know. If I were you I'd probably copy and paste each section into Word or something so you'll have it all in one place. This is about the best out there. If this solves your problem PLEASE rate this as fixed. ( I looked alot for you). If you need more help just add a comment and I'll be happy to assist you further. If this doesn't solve your problem let me know before you rate and I'll try for something better. Thanks.
http://support.radioshack.com/support_electronics/36547.htm
Jeff
Posted on Jun 11, 2008
smartr10U
  • 1305 Answers
SOURCE: need instructions on how to program
You can get the owner's manual for your scanner by clicking HERE
have fun...
Posted on May 26, 2009
danielizapat
  • 107 Answers
SOURCE: how to program radio shack pro 82 scanner
is it a digital scanner? You know that everyone has gone digital there fore making that kind of scanner outdated and if you are trying to listen to police u wont pick anything up. I was told that some raido shacks will re program it for you.
Posted on Oct 11, 2009
BillB-SA
  • 2761 Answers
SOURCE: Scanner not picking up local police-Fire freq
Do you still receive NOAA weather frequencies? Sounds like your local agencies have switched from simplex/standard frequency operation to trunking. I suggest you visit www.RadioReference.com to view the latest on active frequencies and systems in your area.
Bill B
Posted on May 17, 2010
I purchased radioreference premium, downloaded ACR300, downloaded Win97 bought cd download from radioshack and have the USB chord. Man this download is a **** kicker. still can not download freqs or t
Hi Kelly,
The best way to program any scanner is manually, rather than via software. Those things are fine if you know what you're doing, but it takes the fun out of learning how to use your scanner your way.
Downloading a frequency list for your location is as easy as searching the web by typing scanner frequencies for {you location}
Programming your scanner with only the frequencies you want from a list of local frequencies is better than filling it with frequencies you really wouldn't listen to anyway.
The Pro 97 is a relatively easy unit to program manually using the keypad.
Plus, you can download a copy of the user manual from the Radioshack web site or go instore and ask foe a copy for a very small fee(if at all), it will guide you through the steps of programming in a very east to understand way.
Highly recommended, and the return in scanning the airwaves is the best result.
I hope I have been of assistance to you.
Cheers,
Peter
Feb 06, 2013 | Radio Shack Pro-97 Handheld Scanner
HOW TO PROGRAM 2026
Here's a link to Radio Shack's operating and programming instructions for the PRO-2026:
http://support.radioshack.com/support_electronics/doc16/16902.htm
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B.
Listening in since the 60's
Dec 16, 2010 | Uniden BC248CLT Base Scanner
Realistic patrolman pro16A radio scanner, do not know how to program freq, this scanner does not have crystals, does anyone know how or have a manual??
I have checked several sources, and they all show that the PRO-16A is a 16-channel VHF/UHF CRYSTAL scanner. Remove the bottom cover and you should see the crystal sockets.
http://radiopics.com/RS-Realistic/PRO-16A.htm
Bill B.
Oct 14, 2010 | Radio Shack Radio Communications
How do I reprogram the Radio Shack PRO- 2026 Police Scanner
To program a known frequency into the scanner:
- Power the scanner ON.
- Press MANUAL to stop scanning.
- Enter the number of the channel that you wish to program.
- Press PROG.
- Enter the frequency, including decimal point.
- Press ENTER.
The frequency is now programmed into memory. To continue programming, start over with a channel number, or just press PROG to advance to the next channel.
For more details on programming your scanner, follow this link:
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 09, 2010 | Radio Communications
Programing trunk system
the only way I know to program trunking would be manually one freq at a time unless you can find the software and cable to the unit.
Jun 01, 2008 | Radio Shack Pro-97 Handheld Scanner
Scanning Freq
According to the manual the Pro 94 should cover that frequency.
Please note, certain frequencies are blocked in some countries. I see no reason why 217.031 should fall into this category although the closest may be 217.030 which should be close enough
Take a look at the manual >HERE< which should help you to program your scanner.
Best wishes...:-)
Mar 17, 2008 | Radio Shack Pro-94 Scanner
Pro-97 scanner recieving problem
try going to a urban area and scanning the NOAA band. if that works your programming is wrong and there is nothing wrong with your AM/FM base band. also the BNC antenna connector on the inside is notorious for breaking away from the board, nothing a little solder cant handle. Also make sure your local freq's are not Digital
Dec 05, 2007 | Radio Shack Pro-97 Handheld Scanner
1000 scanner radio shack
press the manual button a few times, and make sure there are actually some freq. programmed into the unit. if there are freq other than 000.000000 in there, press the s/s (lockout) button and see if this unlocks the frequencies to allow them to be scanned.
Aug 19, 2007 | Radio Shack Pro-94 Scanner
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
