Question about Samsung Televison & Video
Samsung TV with audio but no picture and no LED backlights. Flashlight test reveals screen image present. No signs of internal damage or disconnected wires. Suggestions?
I have a 28" Samsung TV (model UN28M4500AFXZA- version BB02, 2017 manufacturer date). The TV plays audio from all sources but it displays a black picture/no picture. The flashlight test in a dark room reveals a screen image is visibly present but there are no LED backlights visible on the rear of the TV. I disassembled the TV and no visible signs of damage on any boards, disconnected wires, etc. The toggle switch on the rear of the TV does not function to power up the TV so only recourse is to power on with the remote. ShopJimmy video tutorial suggests highly likely issue is with the "LED Driver" and not the main board or the t-con board. This model does not have a traditional power board but does have an AC adapter. Wondering if the toggle power switch (the part is referred to as a "P-Function Board" on ShopJimmy) is the culprit as it doesn't operate or if the LED backlight strips need to be replaced or perhaps both need to be replaced? Suggestions?
2 Suggested Answers
SOURCE:
gopakumarg43
  • 76046 Answers
SOURCE: 2nd try see last sentences....lg led 32ln5310 tv, sound but no picture, no backlights, nothing visible on flashlight test, what should I replace? Main board, T-Con Board, Power Supply board or Leds
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Feb 10, 2017
I have a Samsung UN50EH5000FXZA TV with no picture. I've replaced all 3 boards and the cable between the main and T Con boards. Any ideas?
It sounds like you received a bad replacement board, happens a lot of buying from ebay...if you can see light in the panel the LED's are working
Sep 15, 2018 | Samsung Televison & Video
TV has sound but no picture
The Audio and Video are two separate components and operate independently of each other. Therefore: The Video portion requires technical repair by a technician with the proper test equipment.
Jan 31, 2018 | Televison & Video
Can you help me troubleshoot my TV? It has audio but no picture.
Use a voltmeter to confirm all the voltages are present when the TV is powered on. If they are all correct then replace the led driver.
Jan 13, 2018 | Samsung Televison & Video
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
Oct 13, 2017 | Samsung Televison & Video
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 18, 2017 | Samsung Televison & Video
Samsung led tv un55h6203af doesn't have any back light but has sound
If you have done the flashlight test and an image is present on the screen when the light is shined from behind then the backlight or the backlight regulator is defective, both should be replaced.
Feb 16, 2017 | Samsung Televison & Video
When testin a power supply or led board on tv do i test dc or ac with multimeter?
Your power supply board is working if you get audio and imgaes.
You test AC only the AC side of the transformer before the Rectifier Diodes. Everything after the Diodes will be in DC.
did you get to see any spec of backlight as shown in
LCD LED TV Repair No Image Blank Black Screen Flashlight Test How to Fix...
Mar 23, 2016 | Televison & Video
What should I replace next, I have a samsung lcd with no backlights but picture shows with a flashlight in a dark room.
sir,
even if you changed the back light inverter the fault remain as same, it seems to be the back light LED is damaged carefully remove the outer frame of the panel then dis connect the LCD then remove the frame of the defuser screen , take out plug your TV, check the LEDs
Feb 15, 2016 | Samsung LN46E550 46 inch LCD HDTV 1080p...
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Televison & Video Logo
20 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
