Question about Tools & Hardware - Others
How to engage crossfeed on a Harrison M350 lathe? Push pull knob on skirt will not move.
SOURCE:
  • 1894 Answers
SOURCE: TThe pull-push stop-start knob does
i think the knob is faulty
may be a small misplacement of some some support ring
Posted on Jun 25, 2008
SOURCE: Washing machne problem
The help that you gave me was completely wrong. The support ring was okay. I solved my problem by buying a new timer and control knobs. The teflong 'gears' were worn out so the knobs rotated freely.
Ronald Nelson
Posted on Jul 13, 2008
  • 67 Answers
SOURCE: Can't pull choke knob up on my riding lawn mower
take the cable off the mower and clean it in a pan with solvent or brake cleaner spray. you can coil it up to fit the pan while soaking. afterwards, let dry --- if you have an air compressor blow it dry to help clean and dry it --- then oil it up with a light oil or wd-40, wipe it off, stretch it out, and work the cable again before you remont it. the cable will stick if it gets too dirty and has no lubrication. may want to buy a new cable but they usually can be cleaned and lubricated.
Posted on Jun 25, 2009
Tnsiouxfalls
  • 617 Answers
SOURCE: looking for a instruction manual for a harrison 140
http://www.lathes.co.uk/harrison/page19.html
Try here.
Posted on Jan 29, 2010
blueextc3221
  • 15935 Answers
SOURCE: hotpoint washer mod wlw2500b selector switch not engaging
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!
Posted on Sep 14, 2010
Kenmore 80 Series washer wont turn on from the push-pull knob.
On this type of washer, you have to push it in to engage the dial and rotate it slightly clockwise then pull it out to start filling.
Feb 11, 2017 | Kenmore Washing Machines
Bladesdoturnwhenengaged
your belt has most likely jumped out of it's intended route, or has broken, check with engine NOT running keys out switch off, pull engage knob and try to manually move blades if they move while knob is engaged, belt is broken or off track
Mar 21, 2014 | Husqvarna Garden
LED that illuminates the stitch selection bar quit working as did the up/down needle button.
Check your bobbin spindle. If engaged (pushed toward the right) LED will not light. When the clutch knob is pulled out, when you wind a bobbin, the up & down needle will not move. So you must push the clutch knob in again to let the up & down needle go up and down. The clutch knob on my machine is in the large hand wheel upper right side of my machine.
Jul 17, 2011 | Janome 4623 Mechanical Sewing Machine
The set knob on my kenmore 70 series top load washer is stripped and I can't figure out how to remove it. The knob just spins and will not move inner set arrow to proper load cycle
flip up the controls
The timer has a hollow shaft. The tip of the shaft has
ears on it. To keep the knob on there a small rod is shoved up into the hollow shaft. The rod spreads the tip and retains the knob. To remove the knob pull out the rod a half inch and the knob and skirt is easily removed.
This video shows how to get into the machine:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 03, 2011 | Washing Machines
General Electric WHDSR209DWW Top Load Washer. Timer works but has lost proper synch with knob and skirt. Can force timer to a position that will run the machine from an unknown starting point. When knob...
Hello:
Its either your knob is stripped or the timer itself is..Most commonly its the knob assembly that's bad.(part# WH01X10061) I would try it first since the knob is only around $7.00 where the timer is around $140.00or so...
Good luck
Jun 04, 2017 | General Electric WHDSR209DWW Top Load...
The knob on my kenmore elite won't move the timer.
The knob itself turns the switch on . The skirt move the timer position. Try turning the skirt. You probably have a broken knob. On these the knob is held in place with a plastic rod inserted into it all the way. This spreads the tip and retains the knob. To get the knob off to yank out the skirt for a look see you need to pull that rod out a tad to release the knob. 88be11a.jpgThat shaft has a rounded end on it that spreads out and locks the knob on. Clever ain't it? These timers are cheaply made, if you cannot find fault with the knob or the skirt then you is gonna need a timer.
Jun 05, 2010 | Kenmore Washing Machines
I have a Maytag Dryer Model # DMDG9206aww and my problem is the timer is not timing out the dryer will just dry clothes all day. Please Help!
The timer (part number 33001624)is obviously stuck; fiddle with the knob a little bit to see if it will unstuck. Otherwise the timer must be replaced; disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Carefully lift the timer knob and dial off the timer shaft by pulling the knob away from the face of the console. Remove the timer dial skirt then remove the two timer mounting screws exposed.
Lay a piece of towel or cloth across the top cover of the dryer then remove the three screws securing the console rear cover plate across the rear top edge of the console. Grasp the top of the console then gently rock and roll it to the top cover of the dryer.
Remove the defective timer then install and secure the new one into position. Disconnect the wires from the defective timer and connect it to the new timer one at a time to prevent messing up the wires. Push in the timer knob into the shaft then reinstall the console in place. Roll the console back into an upright position to engage the locking feet into the slots in the top of the cover and secure it with the screws.
May 24, 2010 | Dryers
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
How the hell does the skirt go on this piece of ****?
Put the metal frame on the board - then turn them upside down. The skirt has four slits - where the knobs on the bottom of the board come through - pull the material tautly while snapping on buttons.
Mar 17, 2009 | Kolcraft Light Vibes 18270 Crib
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
Bill Boyd
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
