Arrow #604 wide crown staples; they come in regular and heavy duty and several 'prong' lengths. The flat top must be 1/2" fo.r the TRE300
The size & code of staple is usually on the side of the tool , ie 80/ 14 means it takes an 80 series staple & max staple length it can take is 14 mm. Hope this helps
SOURCE: Stanley Pneu Roof Stapler Troubleshooting
Sorry for the delayed response, I just found this one...
The issue with depth is usually one of 2 things:
1) Insufficient pressure (bad regulator on compressor or incorrect setting).
2) Bad seals within the gun.
When was the gun last serviced? Have you looked at the O-rings for any signs of damage? All it takes is a little leakage of pressure and the plunger won't have enough thrust to set the staple as expected.
Dan
SOURCE: Stanley TR70 Manual Stapler won't accept Arrow 1/4" staples
It sounds like you have a light duty stapler and are trying to use heavy duty staples. 1/4" refers to the length of the legs not the thickness of the actual staple. You probably just need light duty staples.
There should be a pusher that is attached to a spring. If the spring broke, or the pusher is missing the staples will not stay in place.
If you can locate a model number on the tool, you go to bostitch.com to find the parts you may need
