Question about Home Security
Wireless doorbell WD-1040 purchased last week. Button will not activate sound. How can I return? It's a useless product.
Wireless doorbell WD-1040 purchased last week. Button will not activate sound. Wall unit sounds when inserted. How can I return? joseph.dyer@umb.edu
SOURCE:
SOURCE: Sound cuts out for long periods of time
I've just been having this problem (sound cutting out every now and then) and decided to get round it by plugging in some speakers to the headphone socket. While doing it I noticed that the in-built speakers would sprang back into life. Since doing this and getting the sound back I've noticed it hasn't cut out again.
I think there might be a problem in some units with the bit that cuts off the in-built speakers when you plug in external speakers. My proposed solution is to prod a mini-jack from anything into the appropriate socket (on the left of the TV) and wiggle it around until the sound springs back.
Dave
Posted on Feb 06, 2008
  • 905 Answers
SOURCE: my pushbutton doorbell activates my neighbor's chime
in the chime box and remote you can change the setting for the remote signal that is picked up( refer to your manual for the correct settings) these will be a set of pin connections in the chime box and in the remote switch that will have to be set to another selection
Posted on Dec 29, 2008
SOURCE: my doorbell also ring neighbor's bell
Change pin configuration on plugin bell and the remote.
The pin configuration should match
Posted on Dec 30, 2008
  • 28 Answers
SOURCE: My Desa Specialty doorbell doesn't ring..I have
Batteries are located in the doorbell push button case in the back. Slide open a compartment to reveal the batteries.
Posted on Sep 01, 2010
  • 131 Answers
SOURCE: I have a Siemens Wireless
Hi
To fix the issue you need to remove the batterys from both the bell push and the bell unit for 10 mins, then replace the batterys and then push the bell push so it can switch channels and be different from the house down the road
Posted on Nov 07, 2012
How do I change the battery on the Door Push Button?
Easy....You'll need a very small screw driver. There's a small hole on one of the long ends (most are rectangular in shape). For the brand of door bell I have (Thomas and Betts/Carlon), you push in and downward with the screwdriver. This pushes out the bottom (back of doorbell button). In my case, there are (3) CR 2032 Button Cell batteries in a stacking position. As a quick side note -> If your wireless doorbell button does use button cell batteries. Look to Ebay to purchase them. You can get 6-10 batteries shipped to your front door cheaper. Rather than 3-4 batteries at a retail store + tax...Hopefully, I have lent you some assistance...Thanks for reading
Apr 25, 2015 | Carlon Wireless Doorbell system with...
Id like to change song on my doorbell Dimango model 4330 r cd chime reciever
The webpage http://www.dimango.com/dc-cd-quality-doorbells.htm
shows:
Wireless Doorbell CD Quality Door Chime
Model RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
  • Plays three selectable sounds
    1. Ding Dong
    2. Dong
    3. Westminster Chime Click To Hear Sound!
  • Set sound conveniently at button
It seems that there is a button on the receiver/speaker. Try press once and see if the sound changes.
Nov 27, 2013 | Desa International White Wireless Plug In...
Model WD 1140-ACEPI
Do you mean the IQ America wireless doorbell? If the product is the WD 1140 - A doorbell, then the push-button transmitter uses a CR2032 Lithium battery. You will need to unhook the push-button unit from the base and then pry the front cover up to access the battery compartment. Use a small flat-blade screwdriver.
I hope this helps.
May 01, 2013 | Simplex 4905-9914 Signaling Appliance...
We are installing the doorbell and here is how we have it set up: the 18 volts off transformer red wire going to transformer on doorbell, negative wire going to outside button, red wire from button going...
need more info. Doorbells do not need 2 xfrms. The red off 24 volt xfmr foes to door switch and returns on white. If you have 2 door switch one switch to front door label on doorbell and the 2nd goes to back door label. What is the brand and model number/ I'll try and walk you thru it.
Jun 21, 2017 | Heath Zenith Designer Series...
I have just purchased a wireless doorbell but it does not explain how to change the tune, please help.
Most wireless Door bells go ding-dong! Does your doorbell play Greensleves, or Home on the Range?
Did you get 2 buttons with it?
One is for the front, which makes the bell chime one way and the other is for the rear and it makes it chime differently.
Jun 29, 2011 | Vacuums
Hello I have now got 2 (two) of these units over the past 8 months and neither work----changed batteries--interchanged push button---changed main unit--nothing works----but when my neigbour across road has...
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Jan 04, 2010 | Desa International White Wireless Plug In...
I changed the batteries on my door bell, and it still wont ring
Troubleshooting
Chime does not sound:
• Make sure the doorbell button and the chime codes are the same (See pages
2 and 3).
• Check orientation of doorbell button battery (See page 3).
• Check the doorbell button and chime batteries, replace if necessary.
Batteries seem OK, but the chime does not work when installed:
• Do not mount the chime or doorbell button on metal or near metal studs. This
reduces the transmitter range. Use 1/4" to 1/2" (6 to 13 mm) wood shims to
move the chime or doorbell button off the metal surface.
• Don't mount the chime too close to ground level concrete slabs. This may
also reduce the range. Mount the chime away from the floor.
• Try different locations for the chime closer to the doorbell button. Also try to
orient the chime at a different angle to increase the range.
The range of the doorbell depends on location, temperature and battery
condition.
Regulatory Information
This device complies with Part 15 of the FCC Rules and RSS-210 of Industry
Canada. Operation is subject to the following two conditions: (1) this device may
not cause harmful interference, and (2) this device must accept any interference
received, including interference that may cause undesired operation.
The user is cautioned that changes or modifications not expressly approved by
the party responsible for regulatory compliance could void the user’s authority
to operate the equipment.
Technical Service
Please call 1-800-858-8501 (English speaking only) for assistance
before returning product to store.
If you experience a problem, follow this guide. You may also want to visit our
Web site at: www.hzsupport.com. If the problem persists, call* for assistance
at 1-800-858-8501, 7:30 AM to 4:30 PM CST (M-F). You may also write* to:
HeathCo LLC
P.O. Box 90004, Bowling Green, KY 42102-9004
ATTN: Technical Service
* If contacting Technical Service, please have the following information available:
Model Number, Date of Purchase, and Place of Purchase.
No Service Parts Available for this Product
Jan 02, 2010 | Desa International White Wireless Plug In...
Home Security Logo
21 people viewed this question
Top Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
