Question about Sanyo Televison & Video
Is there a fuse in my sanyo 50 inch flat screen model number DP50843
SOURCE:
SOURCE: tv has sound but picture is black
good day.
The crt circuit of the unit might be loose or the the parts inside the board is loose. Have it hecked by a technician first. Minor parts inside might caused the problem.
Response is highly appreciated.
chris
Posted on Mar 29, 2008
SOURCE: ysus board number for a sanyo 50'' plasma model dp50747
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is www.sanyoctv.com and the phone number is 1-800-877-5032
Posted on Apr 01, 2009
jan mczeal
  • 632 Answers
SOURCE: my 50 inch zenith plasma tv model number Z50P3
The problem lies in the X-Drive boards or the TCPs (tape carrier packages) and they are not serviceable. Once faulty the X-Drive boards must be replaced. The worst scenario is a bad TCP because it indicates a bad panel and you have to replace the panel.The X-Drive boards deliver color information to the vertical grids of the panel through the TCPs. That's why when a fault occurs in the TCPs, vertical black bars appear on the screen and an a much larger part when an X-Board fails. Your TV uses three of these boards, one each driving the right, center and left portion of the plasma panel. The left X-Board has eight TCPs and seven to each of the right and center X-Boards. In your case, the vertical grids driven by the center X-Board is dead but you can't tell the board has failed, It is due to the fact that both the right and left boards are okay but only two TCPs are good on each of them. Meaning there are six bad TCPs on the left board and five on the right. Remember a bad TCP indicates a bad panel and you have at least eleven bad TCPs. The only solution here is buy a new panel or probably a salvaged one auctioned on ebay or have your set or its parts auctioned on ebay then buy a new plasma TV.
Posted on Dec 04, 2009
Raditronic
  • 196 Answers
SOURCE: sanyo model # ds27680
cold solder in vertical ic or bad.
Posted on Apr 21, 2010
gopakumarg43
  • 76046 Answers
SOURCE: 42 " flat screen Sanyo. no picture no sound, power yes!
The main board should be checked. For more details Type in this site name < Electro-help> (DO NOT copy and paste the site name from here. Doing so may lead you to wrong place) to search box of your search engine [not in the address bar of your browser], and press "Enter".
It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site, either at the bottom part of first search page, or at the top of second.
Detailed descriptions are there to help you.
Check the associated ads related to electronic spare parts. You might get details about the availability and price.
Posted on Jun 08, 2012
Sanyo dp50843 no power
There could be an open internal fuse or power supply failure.
Oct 14, 2016 | Sanyo Televison & Video
What are my options for a cracked sanyo dp50843 TV screen
Have screen replaced (search the net.) for prices on new and used or replace TV.
Feb 10, 2016 | Sanyo REFURBISHED DP50843 50IN 1080P 60HZ...
How to change fuse on a sanyo 46 inch flat screen model number Dp46841
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 21, 2016 | Sanyo Televison & Video
On a plasma 50 inch tv Sanyo model number DP50749 it got black line coming down the front of the tv, what is the problem
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 04, 2014 | Sanyo DP50749 50 in. Plasma TV
Please tell Sanyo flat screen TV model #dp42d23
If it is less then 1 year old Sanyo may fix it free . other wise get a quote as it may cost the price of a new one.
Oct 29, 2014 | Televison & Video
My tv won't turn on / no power
Is it plugged in? Please be more specific. Is there anything else like the LED flickering? etc...
Jun 16, 2014 | Sanyo Televison & Video
Sanyo dp50843 50in powers on but no picture or sound
Contact the authorized service center for Sanyo. It will be best in this case. Sounds like a main board fault. Gopakumar Gopalan Google
Mar 10, 2014 | Sanyo DP50747 50 in. Plasma TV
Trying to access input function on my Sanyo flat panel screen with sony DVD remote
Its 50-50 at best that it will program or work.
Another option is take the bad remote to a repair shop--where I work we fix most of them and usually under 20 dollars.
May 28, 2012 | Sanyo Televison & Video
I am trying to locate a fuse for a Sanyo plasma model number dp50747 it is the fuse right next to the power suppl. it shows ft10ah250vp on the fuse
thats a 10 amp fast blow fuses rated for 250v
You can get them at any Radio SHack Store
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Apr 01, 2010 | Sanyo DP50747 50 in. Plasma TV
Ysus board number for a sanyo 50'' plasma model dp50747
Mar 16, 2009 | Sanyo DP50747 50 in. Plasma TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
