When the printer on the display shown the error 55.40 hp lj 2300 dn
SOURCE: HP 2430tn lj printer with 13.20 jam inside top cover error
This question is directed at Steve from the post above. I need to order the sensor you mentioned. Is that sensor located exclusively on the power supply (Part number RM1-1505-000CN)? Will I need to order the whole power supply, or can I order the sensor separately? It does not show it very clearly in the service and maintenance manual. Thanks for the help!
-Shawn
SOURCE: 57.70 error messages for hp
Error 57 is generally a fan fault ; on the LJ9500, 57.70 is indicating a fault with the fuser fan in particular.
plz do rate this post
SOURCE: HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
SOURCE: hp LJ P3005DN hangs during boot. Sometimes during
It would not surprice me if you have a defective formatter board. This is a very commen problem with this machine. Officialy you have to replace the formatterboard but there is also an other way to fix it. Put the formatterboard in to a preheated oven 190 degrees Celcius (350 fahrenheit) for 8 minutes. 8 out of 10 times it works fine fine and the machine is up and running. If this does not work you still can replace the formatterboard.
