I also took to Hyundai to check it i was told its speakers, when i checked the speakers only on speaker blown there rest of the speakers are ok
SOURCE: radio shows on but no sound to speakers
I flooded my Eclipse and the AMP is under the passenger seat. Might have got wet and ruined it. They are expensive from the dealership ($900). Try a junk yard.
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
SOURCE: Rear-Left Speaker Not working
Speakers inop are very common in trailblazers. It is 99% of the time the speaker.
SOURCE: No Sound from Speaker
sometime it is possible for a speaker to make no noise when blowin, just like sometime u will see smoke coming from the speaker when it blows but not always, have u tried replacing the speaker with another one?
SOURCE: Sherwood RX-5502 receiver - get
After doing all this troubleshooting on your receiver, Check if master volume on the surround levels are too low. Adjust master and surround level.
There may aIso incorrect selection of the input source. Select the correct input source.
If after doing this the problem still continue, it means the sound ic in the receiver is damage. the sound ic brings out the sounds from the receiver. You will have to open the receiver to locate the sound ic in the receiver and use the multimeter to read capacitors and change the damage ones.
Thanks for using Fixya.
