Question about Home
Replaced Belanger Ceramic Cartridge in ensuite shower & basement cuz of tepid water. New hot water tank a few weeks ago. After replacing cartridges still have tepid water. Hot water every where else.
    Top Expert:
  • Home Master
  • 63,027 Answers
CALL A PLUMBER LOCALLY
Posted on Apr 15, 2019
2 Suggested Answers
SOURCE:
  • 4357 Answers
SOURCE: I have a single
Check the hot water shut off valve, when the washer fails sometimes the valve itself sticks closed, and sometimes the washer breaks up and clogs water passageways down stream...
To test, pull the hose off of the hot water shut off valve, open the valve and see if you have water flow. (route hose into a bucket, you need more that a small amount of water.....
If you have good water flow from the shut off valve, then you likely have a particle that has lodged in the passageways of the faucet. Reverse flow with air pressure and see what you get out....
Posted on Jul 17, 2011
Why is there no cold water coming out of my shower head
if you live some where that gets cold one of your pipes could have frozen. if you can get to the crawl space/basement put a heater down there for a few hours and leave the shower cold water on if the water comes out of the shower your pipes have thowed out. here is a video https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&uact=8&ved=0CDMQtwIwBGoVChMIn6q266OQyQIVAs9jCh3O6QFj&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DPbnGn9EG1mw&usg=AFQjCNEMOGXppMYQl-Rcij9L-P36CdC8Rw&bvm=bv.107467506,d.cGc good luck
Nov 14, 2015 | Danze Home
MY Moen single handle shower knob turns in a complete circle. From left clockwise, it goes from hot, tepid, cold, tepid, then back to left-hot. What causes this and how can it be repaired?
It sound like you have a Moen Posi-temp faucet and the handle is broken. It is probably an acrylic hdle with a tear drop shaped cover. Take a knife and slide it under the cover to pry it off. Unscrew the center screw and the handle will pull right off. You will see two shoulders inside the hdle, one of which will be cracked and broken. Replace the hndle which can be purchased at any Lowes or Home Depot. Plumbing supplies also carry replacements, but you can probably get one cheaper at HD or Lowes.. Make sure to use the washer provided. It has two flats on the inside of washer. Slide this over the brass stem on your cartridge, NOT on the hdle screw. Install it with the flats of the cartridge in horiz. position. Try faucet. If the water comes out in the opposite temp you expect, warm is cold, and cold is warm, remove the hdle, spin the stem 180 degrees and reinstall hdle.Good luck!
Oct 22, 2013 | Moen & Posi-Temp Single Handle Shower Or...
I have Belanger taps all over the house and there is not much hot water coming out of my belanger shower taps(2 bathrooms), tech said I need to change the cartridge, would this fix the problem? All of the...
the only thing to do is to replace what was suggested and see if that improves the situation if you still have the old leaking one , that would be good enough to prove a point
Nov 19, 2017 | Plumbing
We have two showers one works perfect the other only cold water comes out when turned towards hot nothing happens..what is this
Sounds like the anti-scald pressure balancing piece is stuck. This happens if the shower isn't used regularly. A varnish from minerals in the water causes it to stick. You can replace the cartridge or try cleaning this one by soaking it in white vinegar. When the cartridge is clean you should hear it rattle when you shake it. To prevent it from happening again be sure to run the hot and cold water at least once a week. BTW, if you are the original owner of the faucet Moen will send you a new cartridge free.
Jun 02, 2010 | Moen & One Handle Tub & Shower Faucet
Hot watwer leaks from the hot side of the facet
Replace the stem assembly (ceramic cartridge) with Price Pfister service part #910-030. Be sure to turn water on briefly to flush out any debris in the valve body before installing new part. NOTE: this valve does not like old galvanized plumbing.
May 21, 2010 | Price Pfister 01-31xa Shower Head, Tub...
No cold water from Moen 2253 tub/shower valve, when i turn handle to cold I get hot water, when handle is turn to hot i get hot water
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Apr 05, 2010 | Moen & One Handle Tub & Shower Faucet
Hi my delta single hanlde tub/shower facuet is leaking hot water bad
If its a ceramic cartridge type then replacing cartridge is called for, HOWEVER sometimes cheaper to replace complete tap.
If not ceramic then turn mains off and replace the washer inside.
Jan 08, 2010 | Delta Classic, Single Clear Knob Handle...
Delta 174925 single faucet,only gives Tepid water on ''COLD''
SOUNDS LIKE THE CARTRIDGE ASSEMBLY IS BUGGERED UP. PART #46463.
MAYBE THIS WILL HELP:
All parts and finishes of the Delta faucet are warranted to the original consumer purchaser to be free from defects in material and workmanship for as long as the original consumer purchaser owns their home. Delta recommends using a professional plumber for all installation and repair.
Delta will replace, FREE OF CHARGE, during the warranty period, any part or finish that proves defective in material and/or workmanship under normal installation, use and service.
Replacement parts may be obtained by calling 1‑800‑345‑DELTA (3358) or by writing:
Delta Faucet Company Product Service 55 E. 111th StreetIndianapolis, IN 46280
Dec 15, 2009 | Water Heaters
Low hot water pressure
it sounds like you need to up the temp on your water heater so that you are mixing more cold with the hot .be careful hot water can cause burns if valve is 4 years old then it has a limit stop do not set above 120 *you will need allen key and thermometer to check temp
May 05, 2009 | Moen Plumbing
Home Logo
32 people viewed this question
Top Home Experts
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
