Question about Xerox Office Equipment & Supplies
WHAT CAUSES THE HEATER OF TOSHIBA XEROX MACHINE TO SMOKE
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Xerox Expert
  • 135 Answers
-it may be paper type causing fuser need higher heat to can fuse the toner on this paper kind, so you can check paper type before you print. -the other thing may be thermistor or thermostat defect
Posted on May 15, 2019
SOURCE:
I have a CPU with burnt fuse and board looks smoke damaged wondering whether to replace fuse or entire CPU?
fuse costs about fifty cents , board costs over two hundred , but I would say smoke damage is leaning more like the board me ! Id have a small appliance tech look at it , if there is other parts ruined I missed id rather pay him his diag fee than waste money on a two hundred board that's not going to fix it ! It would go towards a new one
Sep 29, 2016 | Nuova Simonelli Premier Maxi Espresso...
Xerox 8560 is very hot even in sleep mode
the fusers get about 300 degrees to melt the toner to the page. If you do not have the phaser clean regularly, the paper dust that is next to the fuser could smell like it is burning.
Jul 16, 2009 | Xerox Phaser 8560MFP Laser Printer
I have Xerox XD100. Machine is very noise. The noise is coming from back of machine. Sand like motor is turning but something is stock (can not moveThis motor look like suppose to move)
There is a small helix gear attached to the shaft of the main drive motor. It cracks or shreads on the inside. You will have to replace the main motor. Not real expensive or difficult to replace.
May 28, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WCP 416 , it showed message replace drum cartridge
It sounds like you are replacing the toner cartidges NOT the Drum Unit. Drum is located behind the toner cartidge and you will see it after removing toner. Pretty common mistake :)
May 12, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
When i switch on the machine,error E000002 is comming
E00002 on iR3300 is problem on the heater assembly. Replace heater assembly and buy new heater assembly. Good Luck...!?
Feb 06, 2009 | Canon Office Equipment & Supplies
Xerox Workcenter Pro 657 Memory Error
With a 657, most likely the main board has failed. It is not uncommon at all, That is a general problem with that model.
What you can try is, looking from the front of the machine, the main board is located on the back right side. removing 2 screws and releasing the levers will allow you to slide the processor board out of the machine. You can try just reseating,,,, removing and shoving the board back into the machine, and seeing if that helps.
Most likely, either the board has failed, or the memory battery had exceeded its life and the memory is not working.
Wish I had a more positive answer for you, but the 657 is getting older, and those lithium batteries are failing. I have to add though, that those processor boards, have failed pretty frequently over the years.
What you can do is go onto Google and look up "the parts drop" ,,, call them and ask for Britt, and see what he has as far as that producut is concerned. That machine is actually made byn Toshiba, you may be be able to find either a Xerox, or Toshiba repair dealer in your area that has that board and will fix it reasonably. If you find a Toshiba dealer other than a Xerox dealer. Tell them it is the same machine as a Toshiba E-120, they are exatly the same.
Oct 16, 2008 | Xerox WorkCentre Pro 635 Laser Printer
Xerox
They have a scanning lamp and a fixing heating lamp. Xerox is funny when you need some free advice. They don't..... I work on every thing but Xerox, you may want to get in touch with a company called "Parts Drop" on the web. They have Helped me in the past before... Good Luck
Aug 22, 2008 | Canon CLC 1120 Color Copier
Error 13.0 on a Xerox 8550
13.xxx.xxx codes on that machine are heating issues with the print head. Usually the print head has failed or the electronics module supplying the heater voltage.
Thats it in a nut shell.
Aug 05, 2008 | Xerox Office Equipment & Supplies
Open Questions:
21 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
