Question about Tools & Hardware - Others
My hitachinr83a strip nail gun. won hold nail on its track
SOURCE:
  • 65 Answers
SOURCE: air never stops coming out of gun nail,and gun doesn't sink nails
strip and clean the gun ,you will find that replaceing the seals will help no end
best of look ian
Posted on Mar 24, 2009
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
rowdy45176
  • 2176 Answers
SOURCE: how to strip down a hilti dx450 nail gun
I suggest calling 1-800-879-8000 or going to the Hilti.com website and downloading a schematic for this tool. Let me know if you need more help
Posted on Sep 16, 2009
  • 15 Answers
SOURCE: HOw does one load the nailer? Purchased the
You put a couple of drops of oil where you connect your hose. In the air inlet hole.
Posted on Jan 23, 2011
H2_Brad
  • 425 Answers
SOURCE: My nail gun won't fire nails and is blowing It
Stop using it and take it in for service. If it is leaking air then an o-ring or seal may have failed (most likely guess) and it needs to be replaced.
Posted on May 17, 2012
My Pro 8000 stapler has about 20 staples jamed I need to how to unjam thew booklet does not show this
Clearing the Nail and
Staple Chamber
If, while using your Cobra
staple
and nail gun, it becomes necessary to
clear a jam from the staple chamber or
track, follow these instructions:
With the bottom of the gun
facing away from your face and
body, open the staple chamber by
squeezing and pulling the plastic
track release straight down away
from the base of the gun and
sliding the track back.(Fig 1)
(Note: the jammed staple or nail
may cause the track to be harder
to slide out than usual. Once the
staple or nail has been cleared,
the track will resume its normal,
free operation) Loose staples or
nails will be expelled from the
chamber.
Clear any remaining staples or
nails from the track and chamber
area.
Reload the Cobra staple and nail
gun and continue using.
May 17, 2017 | Staples Tools & Hardware - Others
Why might my nail guns not work?
Have you lubricated either nail gun? If not, go to Home Depot and get a bottle of air tool oil. It's in tools by the compressors. Disconnect the air hose from the tool. Pour about a teaspoon of oil into the air inlet of the tool. Reconnect everything and try it 10-20 times with no nails in the tool. Then try it with nails. Good luck.
Sep 14, 2015 | Porter Cable Tools & Hardware - Others
Nails fail to feed
Without knowing your model number here are some things to check, in order of difficulty:
1. First make sure you're using the proper nails for your gun. If your gun isn't specifically listed on the box of nails as compatable make sure they are seating in your gun properly. Some brands of angled nails are a couple degrees off from others and won't work in competetor's guns.
2. Check the entire feed path of the nails in the magazine all the way up to where the driver catches the next nail. Sometimes dirt builds up in the track or there could be a peice of nail stuck in there preventing the nails from getting under the driver. Also the spring on the feed shoe should have strong pressure on the shoe all the way up to the head and the shoe has to ride freely in the magazine.
3. If the gun is making holes in the wood the driver isn't broke but it must be straight and true and the tip square. If not it will miss or slip off the nail before driving it. The only way to check the driver is to remove the head on the gun and take the driver out. The piston & driver should travel from the top to the bottom of the cylinder without binding anywhere. Correct any problems you find or replace any damaged parts and your gun should work.
Feb 13, 2012 | Porter Cable 16 - Gauge Finish Brad Nailer...
How do I load nails into the 5700
Here is the link but I copied the instructions here too
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000035709.pdf
Loading Staples or Nails
Make sure there are no staples or nails jammed from previous usage by checking the handle operation.
CAUTION: IF A STAPLE OR NAIL IS JAMMED, POINT THE GUN AWAY FROM
YOURSELF AND OTHERS BEFORE OPENING THE TRACK AS THE JAMMED
STAPLE OR NAIL MAY BE FIRED OUT UPON OPENING
i) Point the bottom of the gun away from you and turn gun sideways.
ii) Turn gun up, grip track release buttons and push away to release, then slide the track out, as shown (fig. 1).
iii) Insert a strip of staples in the chamber with the legs pointing up (fig.1a). If nails are required, turn gun upside
down and tilt the gun away from yourself and load on the right hand side (as indicated on graphics at the
staple and nail exit) with point facing upwards (fig.1b) THE GUN MAY JAM IF NAILS ARE INSERTED IN THE
WRONG SIDE.
*Arrow
iv) Slide staple or nail track back into closed position - a click indicates that it is locked in position.
Your staple and nail gun is now ready for use.
May 20, 2011 | Garden
I have the nt65ma2 it keeps shooting two nails at once. When you put the nails in do they need to go in the top track ? Or do they slide right in ?
Check that the nail is correct for the gun. Fifteen gauge is a very stout/strong nail and measures around .060. Place a strip of nails along the outside of the rails with nails aligned with rails. The first nail should be aligned with path of driver. If the angle is off do not use. Look at the thickness of the driver (and or condition of, no damage ), the nail should look about the same thickness. If nail is thinner than driver, the second nail in line will be in the path of driver. This could cause damage to gun. I believe that the nails slide in from rear.
Nov 09, 2010 | Hitachi NT65MA2 1 1/4 To 2 1/2 Inch 15...
Not sure how to load nails into magazine
Generally two reasons for nails not to make contact with driver. Make sure that the driver is returning to top of cylinder. If it stays in the path of the nail feeder, the nail cannot slide into position. Second, nails are not the right type or gauge for gun. Some nails even if they are the right gauge have a large head not allowing the strip to enter into chamber. Remove air hose from gun, check that piston is all the way up, then slide nails into chamber and see if they go all the way in easily with-out having to push. You should see the first nail in place from bottom where nail shoots out. The angle of the nail is very important. most pin nailers are 0 degree (not angled), but others have an angle. The gun should be labeled as to angle of nail. Hold a strip of nails against the outside of the magazine and see is the first nail is in line with the driver path. Good luck and post again if you have other question.
Jun 28, 2010 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
With the finish pro 35 can you use any 15 gauge strip of nails,glued or plastic strip
i believe that gun takes 16 gauge nails, and yes, all 16 gauge nails are the same, as long as they are strait, not angled
Mar 21, 2010 | Senco Finishpro 15 Finish Nailer & Sls15...
My gun fires but only loads the nail 20-30% of the time. I tried taking it apart but don't know where to look for the problem. Please help!
The problem will reside in the nail chamber. Most likely you have junk there or a scored feed area. Check the plunger and feed area for dirt and/or scoring to determine what exactly is holding up your advancing of strip nails.
Jan 04, 2010 | Hitachi Nr83a- Strip Nailer-driver Blade...
Nails were installed backwards by accident - now a nail is stuck in the head - how do you get it out?
start by removing all of the screws that hold the track on and remove the track
open the nose piece and you should be able to grab the nail with needle nose pliers
Sep 23, 2009 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Jun 11, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
Tools & Hardware - Others Logo
54 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
