SOURCE: 42" Sanyo HD Plasma TV (Model DP42746)
Scott,
Not at all crazy! The Samsung/Akai lines seem to have numerous problems with their Y and Z sustain boards and upper/lower Y driver boards (aka buffers). That and power supplies are generally the largest percentage of the problems in those units. That said, I'm a bit confused looking at the p/n you referenced. I don't see that as being a Samsung number belonging to a Y-sus board. Usually they start with BPxx-xxxxxx..
Lastly, while you might have every ability to replace the Y-sus board if the buffers are bad and you don't replace them you could simply burn up the sustain board when you power it up... Installing the buffers is a bit more complex than the sustain board so be really careful there...\
Good Luck
Bill
SOURCE: Where can I order a Y-Buffer for my Philips 42
You can try tigerdirect.com. they're known for selling really good products. Just make sure you ask them about their exchange/refund policy though.
SOURCE: Samsung HD 42inch TV Model No. PS42S5H Y Board
Your board numbers should start with LJ92. They will cross to both Samsung and LG. Oh, your model number goes nowhere, double check it.
