Question about Exercise & Fitness
What is wrong when my treadclimber on one side stays down
2 Suggested Answers
SOURCE:
ercupa190
  • 12223 Answers
SOURCE: In the treadclimber mode. One
pull adjustment knob out.Set the swing arm in the position hightest and release the knob to lock the arm in place.
Look at the clips at the end of the cable.If they hang down and are not tight againt the pulley,tight the pulley.
locate the tension knob in the side- Pull the knob and turn the pulley bellow the know clockwise.
Watch the clip above you retract.Stop turning the tension knob when the clip touches the pulley.
Repeat with the other cables. sincerely
Posted on Dec 01, 2011
Disassemble bowflex treadclimber
There are several versions of this unit. If you do not have the manual for this model, I recommend performing a search and downloading it. The manual is an assembly manual. It details the parts. It also has a section on getting the treadclimber ready for transport. Rather than trying to tear down the treadclimber and reducing it to its pre-assembly form, I suggest you examine the transport section.
http://download.nautilus.com/supportdocs/AM/Bowflex/BFX_TM3-5-7_AM_RevD_web.pdf
Sep 27, 2017 | Bowflex Exercise & Fitness
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
The treadles on my treadclimber are not rising and falling evenly. The treadle on the right seems ok, but the left treadle stays significantly lower. I have tried adjusting the dial to a lower number on...
Please RUN the software calibration for easy diagnostic and fix it.
go under the HOOD motor follow the steps, or read your owner manual /download from www. fitness.manualsonline.com
GOD BLESS YOU
Dec 02, 2013 | Bowflex Treadclimber
My bowflex treadclimber tc 20 is putting out error codes H03,H13,H24 whats wrong
I have the exact problem. My machine is 3 days old. I am also getting this H03, H13, H24 error. I called the 1-800 number for the Treadclimber TC20 and they informed me that a handful of machines were sent out with a bad control board. I am waiting for a replacement board.
Apr 14, 2012 | Bowflex Treadclimber
How do you replace the breaker on a tc5000 treadclimber
VERY EASE DISCONNECT THE POWER CORD.
Disolder the wires with Solder Gun, change the breaker and again put solder in the terminal, please do it with carefully, and very tight the terminals.
the breaker is to side from main switch.
sincerely.
Oct 09, 2011 | Bowflex Treadclimber
In the treadclimber mode. One side or the other will stay down as it should come back up with the other. What should I do?
Sep 22, 2011 | Bowflex Treadclimber
Treadclimber tc3000 treads/STEPS WILL NOT GO UP & DOWN EVEN
Sounds like the hydraulic cylinders are bad. Try replacing them and should fix the problem.
Apr 29, 2010 | Bowflex Treadclimber
Bowflex Treadclimber Calibration Failed
Check the wire connection at the bottom of the right upright. Male Female white connectors. if they are good then check speed sensor under the left rear treadle. Must be about credit card distance from drive pulley. Remove rear covers to access. Note you will have to remove both side covers and back cover. 10 Screws.
Jun 23, 2009 | Bowflex Treadclimber
Bowflex Treadclimber tc 1000 turning off
Napa 8300 silicone. Spray on each walk deck under the belts. just a quick shot from front to back in a fluid motion. test unit and see if it still shuts down.
Jan 29, 2009 | Bowflex Treadclimber
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
