Question about Alcatel Cell Phones
Alcatel a577vl won't turn on displays "Secure Boot Failure ". How do I fix it and why did it happen?
How can i bypass a google lock on a alcatel A577VL it was factory reset and i dont know the owners previous account
If it was factory reset, there will be nothing on it to ask for a previous code. Use your google account.
Jun 03, 2018 | Alcatel Cell Phones
I have recently bought my alcatel pop and was so pleased with it, but now i can t get it to charge or turn on, can you please help?
Please try the below steps:
1.Try another charger
2.Remove your battery and try to charge/turn on phone while connected to verified working charger
3.try another wall outlet
Let me know what happens so that I may further assist you.
Jul 22, 2016 | Alcatel Cell Phones
My alcatel onetouch 5020d freezes on boot
Sounds like it has been damaged. The only other thing I can think of is remove the battery for a few hours and try again.
Nov 28, 2014 | Alcatel Cell Phones
Hp compaq desktop black screen message disk boot failure insert system press enter
The words "disc boot failure" are terrifying for most computer users.
A disc boot failure notification generally means that your hard drive and operating system may be useless.
Fortunately, there are a variety of ways to troubleshoot your system in order to salvage your computer.
You may need to restart your computer a number of times before you manage to fix the error, so don't get discouraged.
A couple things to check first, make sure there's no floppy disc/cd in the drives, and if you are comfortable with computers, you can enter the boot setup of your BIOS, and check to see that your hard drive is listed as the primary boot device.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Or there is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Turn off your computer by pressing and holding the power button until the computer shuts down.
Locate the boot disc for your operating system (OS).
Turn on your computer and insert the CD into the proper drive before your monitor reaches the BIOS screen.
If the computer cannot read the CD, eject it and wipe the readable side of the disc with a clean cloth.
Restart your computer and re-insert the CD.
If this does not begin to load your operating system
Restart your computer and press the "DEL" key when you reach the BIOS screen.
This will bring you to BIOS settings.
Make sure that your hard drive is enabled to be read by BIOS. Restart your computer.
Access the command prompt by pressing the "F8" button at the appropriate moment.
Your monitor will display a notification at the bottom of the screen when you can access the system options with "F8." From the menu that appears, select the "Command Prompt" option.
Enter the text "fdisk /mbr". On the next line, enter "sys c:" and press "Enter."
This will initiate a system restore of corrupted discs.
If this does not clear the disc boot error problem.
Turn off your computer and remove the power supply.
Remove the side panel from your hard drive tower by hand or with a screwdriver.
Locate the hard drive of your computer in the top-front section of the hard drive tower when viewed from the side.
Using your fingertips, make sure all connections to and from your hard drive component are secure.
Locate the BIOS battery, which is a circular battery found on the motherboard.
Make sure that all connections to and from the BIOS battery are secure.
Check the connection of your computer's RAM to your motherboard.
hope this helps
Oct 14, 2012 | HP Compaq Presario SR1950NX PC Desktop
Toshiba nb300 windows starter won't boot. PXE-E61 media test failure. check cable.
If your computer is working fine, then disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
For the most part not a real problem. More of a warning. Some corporate models use PXE to mass image.
If there is a problem (won't boot) then it lost communications to hard drive, and you need to check BIOS for hard drive.
Oct 03, 2012 | Toshiba mini NB305N410WH Netbook
Dell inspiron530 won't boot and beeps four times stops and beeps again
The Beeps are a beep code 4 means you have a ram read/write failure. Or a possible motherboard failure in that case you will need to contact Dell or replace it yourself.
Oct 01, 2012 | Dell Inspiron 530s Desktop Computer
Our new hp monitor won't restart after computer is taken off sleep mode the screen will show a partial screen saver but it won't display icons until you turn off monitor and turn back on
is this only your monitor or is it your computer as well
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) Ide/Sata make sure they have a secure connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust in its socket
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Sep 13, 2011 | HP Computers & Internet
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
Cell Phones Logo
52 people viewed this question
Top Alcatel Cell Phones Experts
D. E. Hev
Mark Snell
Dakshinamurthy...
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
