Exercise & Fitness Logo
Michelle ojeda Posted on Apr 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My treadmill is not rising on one side what is wrong with it
Treadmill Repairs Brisbane
Level 2:
New Friend:
  • Expert 338 Answers
  • Posted on Apr 28, 2019
Expert
Level 2:
New Friend:
Answers
338
Questions
0
Helped
77827
Points
473
What brand and model is the treadmill please ?
2helpful
2answers
The bread won't rise like it used to. Not the yeast. What's wrong with the machine?
Is the the flour? Have you tried different recipes and does the same thing happen? Too much salt can prevent rising, or not using rapid rising yeast. good luck.
How do i remove treadmill front roller
Hey, I really think you should have mentioned the brand of treadmill but however all the treadmill i encountered all function on the same principles... though some may seem more of a hassle to do they are all the same (correct me if i'm wrong)... So with that being said you would need to remove the motor housing cover by removing all the screws around the sides and front of the machine. By now you should have a clear view of the front roller, on one side you should the the belt driven pulley that is held on by the belt alone so removing that along with the bolt on the opposite side should do the trick.... lemme know if this helped
Unit will not rise incline
Please RUN the software calibration for easy diagnose and troubleshooting. However Lube the elevation motor+shaft+gear+pinion+adjust the small POTENtiometer a little. see the diagram attached and proceedGod bless you
Reebok tr2 incline wont work, back of machine starts to rise when you prees the incline up button
1) lube the motor elevation, shaft +gear and adjust the POTentiometer a little
2) see the diagram attached,
3) Run the software calibration for troubleshooting,
4)test the relais for open or faulty coil,and clean the contacts very well
God bless you1_22_2013_5_10_05_pm.gif1_22_2013_5_10_34_pm.jpg1_22_2013_5_11_02_pm.png
Our Nordic Track C2255 has worked great... until today. I went to start it and after placing the saftey magnet to turn it on, the incline rises and keeps trying to rise even after it has reached the max %...
Watch the videos+Tip:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
12_1_2011_4_57_07_pm.gif12_1_2011_4_57_26_pm.gifObserve as the main motor controller board has 90% of functions of the any treadmills. Now you will have powerful resultant and determine what is wrong.
good luck, sincerely G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA
I have a ET-388 threadmill. however when i walk or run on the machine the sound is very heavy. can you tell me what is wrong of is it normal?
hi,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
2helpful
2answers
Treadmill wont incline all the way
With the key in the console, press one of the incline buttons. While the incline is changing, remove the key. After a few seconds reinsert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. Thi will recalibrate the incline system.
2answers
Treadmill smells HOT HOT HOT
Start by lubing your deck with a silicone oil or slipcoat
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
