Question about Golf
Why is it that my golf cart runs good one day and won’t start the next day
SOURCE:
SOURCE: my montana will start one time , run all day ,
You should try cleaning the throttle body - remove the air box from the throttle body spray in cleaner and then work it in with an old toothbrush. I had the same issue with my 2005 and this fixed it right up.
Posted on Mar 21, 2009
  • 174 Answers
SOURCE: golf cart smoking
It is most likely related to the rings, but running it would unstick them very fast if they were stuck. It's possible that sitting let rust develop in the cylinder walls and there may be some grooves in them now. They could also just be really worn cylinders. They make some oil conditioners which I wouldn't recommend on a car, but might work fine on a golf cart. I can't recall the name, but it was in a silver can, maybe called engine restore... You could always try that before resorting to a rebuild.
Posted on Nov 12, 2009
Testimonial: "thanks for your advice. I will try an additive before a rebuild."
prolawnsball
SOURCE: Gas golf cart won't start
try a jump start off of a similar battery with the same voltage. If that does not work, there is a chance your ignition wire is not wired into the throttle anymore. try reconnecting it.
Posted on Apr 26, 2012
  • 3 Answers
SOURCE: Can I leave my 2004 ezgo golf cart charger plugged
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
Posted on May 15, 2012
  • 103 Answers
SOURCE: craftsman air compressor won't turn on. Worked
Motor start capacitor probably bad.
Posted on Aug 08, 2012
What could be causing my golf cart to lose power? In the morning, it barely goes up the hills. It seems to run normally at night, but when I hit the gas pedal the lights go completely out.
Have the battery checked. Especially make sure they do a shunt regulator test on the cells. Sounds light a shorted cell in the battery.
Feb 10, 2018 | Cars & Trucks
Six 8 volt batteries in a golf cart show being ba the golf cart runs as same good bateeries
You load tested each battery? Can't be bad if cart runs good.
Oct 03, 2017 | Golf
I have a 2005 ezgo electric golf cart, I caused a power surge now cart won't run? What did I blow?
This could be really bad. Start by checking total voltage from battery pack. Next check voltage at small posts of solenoid when pressing pedal. No voltage? start tracing the wiring. Voltage yes? then test solenoid. If good then controller might be bad.
May 23, 2017 | Golf
Electric golf cart won't run on cold mornings. I hear solenoid click but nothing happens. When the temp warms up, it runs normal. I replaced controller, solenoid, speed control and ITS & switch.
Depends on how cold it's getting outside. Cold weather is ******* a battery. Try load testing your batteries. That "clicking" noise makes me believe that it's trying to start, but it's not pulling enough amps. Considering everything that you've already replaced, I would start there. Assuming you've already made certain all of your connections are good. Also, make sure the ground wire for your electrical system is good. Not loose, corroded, etc...
You can even call the local golf course and ask to speak to the golf cart mechanic. I would get several calls a week from drivers when I worked as a diesel mechanic.
Oct 20, 2016 | Golf
I recently came across an ezgo golf cart I noticed I m leaking gas out of the petcock valve and was wondering if I can bypass it?
Hi, Sally I would "NOT" recommend bypassing the valve just replace it for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Product Manuals
GO Golf Cart Parts
Cartaholics Golf Cart Forum EZGO Golf Cart Repair
http://www.buggiesgonewild.com/
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 09, 2016 | GAS Motorcycles
Golf cart electric charged but wont run
not enough info to even guess and I won't..
May 19, 2014 | Golf
Yamaha golf cart
Look under the seat for a pressure switch.
Mar 26, 2014 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Golf Logo
47 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
