Question about Jensen Televison & Video
Jensen 401010 car stereo led display lights wont work red blinking light in corner
SOURCE:
BIKER T
  • 909 Answers
SOURCE: bosch dishwasher not working
board needs replacement.
Posted on Oct 08, 2007
SOURCE: Blinking Red Light
just push the button one or two more times at will take a picture while the light is blinking red.
Posted on Apr 29, 2008
IFIXALL
  • 869 Answers
SOURCE: led light blinking
First try a hard reset. Just unplug the power cord for 4 hours or more; then try again.
If the reset does not help it means the problem is hardware failure and not software. Therefore, you will need a tech who can diagnose the electrical circuits. The short circuit conditions could be in any location within the 8 or 10 sections of the tv.
Please Rate This !!
Posted on Jun 12, 2008
MECP Guy
  • 344 Answers
SOURCE: astra remote car starter problem
your remote starter is in valet mode, the door lock will still work but no remote start, try pressing the trunk button 3 times, if that doesn't work turn the ignition switch on and off 5 times
Posted on Jan 09, 2010
SOURCE: tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Posted on Feb 22, 2010
How can i fix my sony tv
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 02, 2016 | Sony Televison & Video
Stereo wont turn on only red light is blinking
It sounds as if you are lacking accessory power to the unit. Insure that the red wire of the Pioneer unit is receiving 12 volts with the key in the accessory and on position.
May 05, 2011 | Pioneer AVH-P5700DVD Car DVD Player
The red light in the bottom left corner keeps blinking and it wont turn on. Yet when i unplug the tv and plug it back in the blue light comes on but then turns into red light blinking again and it wont...
Ur tv power supply board have dead componnents call capacitors.These capacitors are leaking gas,and it bulges up on it top or puff up on it top.These capacitors parts are dead,they must be replaced.U know basic electronic's and soldering?Take ur tv aparts,the board where the power cord plug into it.That ur power supply board,searches all around for these dead gas leakage capacitors,replaced them.Ur tv power LED light will be stable and the tv power will work again.Or tries websites like Shopjimmy.com,ebay.com to buy a whole reburbish power supply board for the replacement.
May 24, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
Astra remote car starter problem
Jan 03, 2010 | Astra Car Alarm And Remote Starter,...
The red light on jensen 850watt amp wont turn off
jensen sucks dude. just sell it and upgrade. red light could be anytihng. chekc your speaker wires and make sure nothing is touching. from the remote start wire(blue) to the amps and subs. chekc and make sure there is nothing touching.
May 26, 2009 | Jensen Car Audio & Video
My in-dash won't come on
yellow lead on car stereo should be going to a permanent live on car stereo wiring loom, (always 12 volts regardless of key being in or out) red lead on car stereo should be going to aux in car stereo wiring loom, (12 volts only when key in and ignition lights on) green lead on car stereo goes to earth to allow you to watch dvds whilst driving (highly illigal whilst driving!) read the manual, if this doesnt work fuse in car possibly gone?
May 10, 2009 | Car Audio & Video
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
Wont turn on
check your fuses and all connections, make sure you have a good ground to the stereo and make sure the yellow and red positive wires are not loose!
Jul 19, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Amp Power LED Display blinks red and no sound
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
Jan 26, 2008 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Jensen (143307) Remote Control
Turn on your tv manually. (without remote)
Hold on to the (tv) button and on/off button for the same time for 3 secs.
On/off button will light up.
Push on/off button until the tv turns off. (1x-10x)
Then push the stop button on the bottom of the remote to save.
Dec 08, 2007 | Jensen 143307 Remote Control
Televison & Video Logo
18 people viewed this question
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
