The TV code for the Bush BMKDVD40 for a universal remote control is 0376. You can usually find the code listed in the manual for your universal remote, or you can search for the code online by typing in the model number of your TV.
Which eeprom and what is your question? The eeprom for the 897545-1 pcb will need to line the little cut out on the pcb with the eeprom. This usually means the pcd goes in upsidedown, with the version of software sticker upsieedown. When you power the machine in, it should count from L9 to L0, then go blank.....Hope this is what you are asking? Remember to power off and remove eeprom after software loaded
press the channel up and down together the menu will come up then you can use the volume up and down to toggle on what you want.if that does not work you will have to call the tech to lift off the eeprom from out of the set and resolder it back,so that the tv could reset it self.good luck.
