Question about Boating
Need to replace the mounting bracket for outdoard mounting transducer that came with my echo 100 fish finder
SOURCE:
  • 16 Answers
SOURCE: fish finder
You have either the DSM250 or DSM300 digital depth sounder module installed. The C80 is not seeing it.
There is an LED status light on the DSM. For starters, it should be lit either red, yellow or green to confirm it is actually powered on. We are hoping for a green light.
Double-check the cable between DSM and C80 for tightness. Also double-check the DSM's power cable for tightness.
The DSM's are sensitive to voltage level onboard. Make sure the DSM's connections to the circuit breaker panel or battery are tight and clean. Double check with a multimeter the there is 12V DC available to the DSM.
Let me know what you find.
Posted on Dec 28, 2007
ward_knutson
  • 64 Answers
SOURCE: i need a manual for humminbird wide 100 fish finder
You can find the manual you need at: http://www.humminbird.com/support/FAQ.aspx?faqid=72
It is listed in the legacy products area with the wide series of units.
Posted on Nov 26, 2008
SOURCE: navman 4500 fish finder w/transom mount transducer
I finally got an email reply from Navman. If the unit is less than two years old (mine is not) they will repair it. If it is over two years old, or if you can't prove that it is less than two years old, you can ship it to them and they will repair it for the low, low price of 355 US dollars.
Pretty nice of them since it appears these units are highly problematic isn't it? I am wondering if they guarantee their fix, or just have you on the hook for another 355 dollars later.
Good Luck Everyone,
Walt
Posted on Apr 30, 2009
  • 597 Answers
SOURCE: installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Posted on Jun 02, 2009
dnewcombe1
  • 1564 Answers
SOURCE: I have an Eagle Fisheasy fish finder & need to replace transducer
You can find out which one is serving the device you wish to repair by waving a small spade or wide metal object about a foot from each of the existing transducers and have someone else monitoring the insruments on the concole.
Posted on Sep 07, 2009
Doesn't work on fast flowing river
Many depth finders don't work when the transducer sees a little turbulence. My only suggestion is to try different locations for the transducer, trying to guess where there will be the least turbulence beneath it. This is easy if your transducer is mounted inside the hull and reads through the hull. Not so easy if it is a through-hull mount. Be sure it is mounted correctly to the hull if it is mounted inside the hull.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Dec 03, 2017 | Lowrance HDS5x Fishfinders
Lowrance Elite 4X fish finder that reads between 1.5' and 2.5'
Hey Anon
The transducer installation is more important than anything.. next to correct wiring! You must make sure the mounting is good,,, if its outside the hull, make sure its sitting 1/16th below the hull with no obstructions.. if its inside the hull, the medium you used to fix the puck to the hull must be porosity free and the puck sitting as level with the WATER as possible..
Now, take the manual to the lake with you and DO NOTHING but read the manual and apply what you read to the unit,,, read -repeat - read-repeat.. forget about fishing... now read-repeat and learn... IF nothing seems to be reading correctly.. its probably the transducer installation.. YOU DID use a/the transducer specifically for this unit!!
Jun 24, 2017 | Lowrance Elite-4x Fishfinder
My depth finder keeps loseing the bottom and just flickers the last reading
Hi, if this happens when stationery check the angle of the transducer, if it only happens when moving check the height of the transducer also. Regards Phil
Jul 02, 2012 | Lowrance Lcx 38c Hd Fish Finder Gps (200...
My hummingbird rf15 smartcast fish finder has stopped scanning.it still provides the water temperature but it no longer displays the depth and does not scan the bottom.
The Smartcast system uses the wireless version of a simple transducer and thermometer to locate fish, show structure and water temperature. From your description, it sounds like the transducer portion of the Smartcast device has stopped working.
Transducers are both simple and complex, sturdy and delicate. Here is a Science Minute: A fish finder electrical signal is sent to the transducer. The electrical signal to energize the transducer crystal is generated by an amplifier. The energized crystal reverberates at a particular frequency, to convert the electrical signal into mechanical acoustic or sound energy. The acoustic energy or sound waves causes oscillation of the water molecules through which the sound travels. The sound is pulsed out in a defined beam. These do not travel out in a straight line but in a wave pattern. The acoustic pulse travels through the water at a rate of approximately 4800 ft (1500m) per second in saltwater and 4920 ft/sec in fresh water.
The problem is that the crystal in all transducers (permanent mount, thru-hull mount and castable) is delicate. It is a crystal. Unfortunately the warranty on most of these is six months, and unless yours is newer than that, you may need to buy a replacement castable. The handheld unit should still work. While I think the idea of knowing what is "over there" is a good one for shore fishing, I haven't bought these systems because I could never get over the idea that repetitive casting of a crystal, no matter how well-housed, was a good idea. Good luck.
Sep 27, 2011 | Humminbird Smartcast Rf35
I get an error msg that the transducer is not connected. How can I check idf the transducer is faulty
If you can find someone with a Humminbird that has the same pin configuration on the transducer cable, switch yours out and put the transducer in a bucket of water to see if it works. Otherwise, make sure the cable at the plotter end is firmly placed in the socket, and that no pins got bent in the past. Some of these models came with a metal clip that holds the end of the cable(s) tight to the plotter and is held tight by the mounting bracket screws.
Aug 28, 2011 | Humminbird Matrix 97 Combo Fish Finder And...
Parts need for Bottom Line Side Finder Tournament Master
Captdave, if you still have a power cable for a bottomline tournament master hr, please email me at scorpion_2_1999@yahoo.com please
May 20, 2010 | Boating
Navman 4500 fish finder w/transom mount transducer
Good Luck Everyone,
Walt
Sep 20, 2008 | Navman F4100SX Fishfinder - W/ Transom...
Installing an old used lowrance fish finder
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
False fish readings
False fish readings are commonly caused by electrical interference such as alternator noise, and by air bubbles flowing across transducer.
For starters make sure your fishfinder is on an independent circuit and not on one powered by your ignition switch. In other words, you should be able to turn your fishfinder on, even though the engine is turned off. Ideally the fishfinder should be wired directly to the battery with an in line fuse.
Try running the boat at a speed slightly higher than trolling speed, then kill the engine, as the boat slows down to trolling speed do you still see false echos? If yes then the problem probably lies with how the transducer is mounted, or where it is located on the hull.
If you don't see the false echos when the engine is off, it may be necessary to reroute the transducer cable to keep it away from the boat's ignition wires. You can get transducer extension cables if necessary. Also there are filters that you can buy that suppress alternator noise buy attaching between the battery and the engine.
Another common cause of false echos from electrical interference is a transducer cable that has been cut and spliced.
I hope this information helps. Please reply if you have any questions about my response.
Feb 25, 2008 | GPS
Boating Logo
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
