Verify that the disc turns, put it in the tray, observe the position, enter it, wait for the indication of "No Disc" and remove the disc, if it is in the same place, apparently, it would have problems in the disc engine
Another way to check if the engine works, play an audio CD, if you read it, apparently the engine, it would not be the cause of the failure
If I notice that I turn, I could have dirt problems in the lens of the reader, proceed to clean it with a cotton swab and if you do not know how to do it, contact a technical service
Another option, it is possible that your reader is under power to read the DVD
Verifique que el disco gire, p?ngalo en la bandeja, observe la posici?n, ingreselo, espere a la indicaci?n de "No Disc" y saque el disco, si esta en el mismo lugar, aparentemente , tendr?a problemas en el motor del disco
Otra forma de chequear si el motor funciona, reproduzca un CD de audio, si lo lee, aparentemente el motor, no seria el causante de la falla
Si observo que giro, podr?a tener problemas de suciedad en el lente del lector, proceda a limpiarlo con un hisopo de algod?n y si no sabe como hacerlo, dir?jase a un servicio t?cnico
Otra opci?n, es posible que su lector esta bajo de potencia para leer los DVD
SOURCE: Denon 3910 won't load some dvds/cds and vibrates while trying.."disc error"!
I have the Denon 2900 (about 4 years of use) and until recently, suffered from the same (growing) problem. CD's were very difficult to start/read. I recently found advice which I tried and was succesful with. It was manually cleaning the laserlens. I took away the outer housing by unscrewing all off the on top (6), side (4) and the back (2) bolts. After that I took out the top plate of the laserunit which took two very little screws taking out. Now you are looking at the cd-tray with the lens. Take a very soft and clean cloth and moisten it a little bit with clean water (be very carefull with the moistening, don't allow any waterdrop to come out of the cloth into the laserlens while cleaning! Carefully clean the lens and dry it with a dry part of the same cloth. Replace the top plate and the outer housing and the player will recognize the discs like it's new again. Good luck! Robert Jan, The Hague the Netherlands
SOURCE: Denon 2910 CD player malfunctions
There has been a number of reports of similar issues with Denon models that utilizes the 'PureProgressive technology'. Some of the issues and tried corrective measures are -
1. It would appear that in certain occasion, performing a "region free hack" disables the 'PureProgressive technology' and one solution tried is to set the unit to NTSC and not multi or PAL;
2. disable/turn-off digital output;
3. some has reported significant improvement when a firmware upgrade was performed;
4. use DVI instead of of other outputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
SOURCE: SONY BDP-S300 WON'T PLAY BLU RAY DVD OF 2012, HAVE
I think sony should reiemburse you and me for this piese o !@!@
