Question about Pride Health & Beauty
I have a Pride Mobility GoGo Elite Traveler Plus will run but it has a constant beep tone.
Battery fully charged, scooter will run but it has a constant beep tone. I have dismantled and assembled and checked fuses. Freewheel lever engaged and disengaged. Nothing I've tried has worked. Has anyone else experienced this, and if so, how can it be fixed?
SOURCE:
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
gewiz
  • 1367 Answers
SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
Posted on Jun 13, 2009
gewiz
  • 1367 Answers
SOURCE: The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
Posted on Jul 25, 2009
  • 14 Answers
SOURCE: we have a 11 month old elite traveler scooter. The...
I just fixed this problem in a Go Go Elite that was less than 6 months old. We would plug in the charger and the "charge" light would not turn on, just the "power light" I took out the battery pack (check manual for instructions), removed the cover (8 philips head screws) and checked the voltage on the two batteries. One read 4.5 volts and the other 4.7 volts. They should both read at least 11 volts, ideally 12 volts. Evidently the Pride charger will not work if it detects that the batteries are too low. So I took out one battery at a time and connected a 12 volt auto trickle charger to it for 3 hours on each battery. Checked voltages and it brought them back up to 11.5 volts. I reinstalled the battery pack and then connected the Pride charger and THEN it showed a "Charge" light. I left the pride charger on for 12 hours and it brought it up to full charge.
Advice: Don't let your batteries get too low or the factory charger will not work.
Posted on Jul 05, 2010
HoverTech
  • 232 Answers
SOURCE: Where can I find a
Contact Pride Mobility at 800-800-8586, they are usually around $20.
Posted on Nov 09, 2010
SC/54. I have 2 of these go go scooters. One gets much longer battery life. Why? Do I need to replace the upper console assembly?
Hi test youre batteries with a battery LOAD TESTER it will give U an accurate reading on there condition U can buy them on E/BAY PRICE APROX $35 ...the gogo that's runs out of power quick might b on the way out a bad cell ..cheers
Sep 13, 2016 | Pride Go-Go Elite Traveler Plus 4 SC54
Need a repair shop to fix my gogo elite
This is due to the controller shutting down. Make the brake leverin the on position
Oct 08, 2014 | Pride Mobility Products Go-Go Elite...
My battery is fully charged but my scooter wont go?
hi, how many bleeps before a pause ? or is it constant bleeping ?
This error can be caused by a bad connection , check where the back end comes away from the frame...
Regards
Rob
www.gewizrepairs.co.uk
Aug 17, 2014 | Pride Mobility Products GoGo Elite...
Why does it constantly beep?
hi, it's it's running okay but bleeping , could be low battery voltage or a failure in the bleeping circuit with wiring or the controller...
Regards
Rob
www.gewzirepairs.co.uk
May 03, 2014 | Pride Mobility Products GoGo Elite...
Pride elite traveler keeps cutting out 9 beeps
it could be the connection between the rear section and the front half. take back section off and see if connection has melted as I have repaired lots with this fault.
Dec 13, 2013 | Pride Mobility Products GoGo Elite...
9 beeps gogo elite traveler
hi, 9 bleeps on a go go mean a parking brake fault or motor connection problem , now it could just a be case of a poor connecting however go you confirm the exact controller used ?
Check the brake connections and motor cable connections making sure they are clean and tight.
Regards
Mar 09, 2013 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Where can I find a repair manual for a Pride GOGO Elite Traveler Plus?
Nov 06, 2010 | Pride New Mobility Victory XL 4 Wheel...
Health & Beauty Logo
29 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
