Question about Xerox Office Equipment & Supplies
XEROX WIDE FORMAT SCANNER IS NOT READY - Xerox Office Equipment & Supplies
2 Suggested Answers
SOURCE:
elix0411
  • 3530 Answers
SOURCE: scanner is showing error 0x00000015
Error 0X00000015 is caused by damaged windows files or broken system structures. This is a critical problem that can cause an unstable operating system, which is typically caused by improper management of the computer.
Please click on this link for the repair.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Oct 03, 2010
Xerox 510 wide format printer error code LL-12
PLEASE INFORM ME
MY XEROX 510 IS DESPLAY ERRORE CODE LL-12
Jul 18, 2014 | Xerox documate 510 - 600 X 1200 Workgroup...
Tip
Xerox 510 wide format only printer!, and not scanner!
The machine does not give me option to photocopy only as printer. The panel comes
March 22, 2004 release day
SE: OK
and does not leave the panel ready (does not load the system as it should be). Please I need your help, URGENT, to solve this problem. I would appreciate suggestions to solve it.
Andrea
on Jun 14, 2010 | Office Equipment & Supplies
What is solution error code in xerox 6204 123-314
I am afraid you will have to call out a xerox service tech, he will have to reinstall the M\C siftware.
Jul 03, 2014 | Xerox 6R1238 6204 Wide Format Printer...
Xerox 3050 fuser replacement
Assuming you are talking about the Xerox 3030/3050 wide format printer, you don't replace the fuser, only the individual components eg. fuser roll
May 11, 2012 | Xerox Office Equipment & Supplies
Xerox Synergix A0 Scanner setup
As far as I know you need either the Xerox Accxes controller (like a dedicated PC) or a wide-format printer with the built-in Accxes controller, like the Xerox 8825 model. The 8825 has the firewire input and communicates just fine with the YWC-1.
Oct 24, 2011 | Xerox One Touch 2400 Flatbed Scanner
I have a Xerox 7356 Scanner which continually says: Not Ready on the display. Any suggestions on how to troubleshoot this problem or where to go on-line to research troubleshooting?
it is likely the lamp.
Easy fix.
Buy a new lamp at a good lamp supply store. Type F32T8 SPX41
Make sure the back plate is white and re-normalize the cameras.
If you get the "NOT READY" message only after you insert an original
then the problem is likely the motion sensor.
Oct 14, 2010 | Xerox 8830 Copier
I require a service manual for a xerox 3030 wide format photocopier so I can learn to install a new toner
Fuji-Xerox XP-11 (Xerox 3030) Toner / OPC
6R281/13R32, 20k Under switched off printer press and keep the button of the unset, residing near by cord of the feeding; include the printer.
Procedure alike for both cartridges
Sep 02, 2009 | Xerox Office Equipment & Supplies
Xerox C 20 photocopier 'scanner blocked' eror message
There is a scanner lock located on the bottom of the scanner. Look where you take your copies out of the machine. On the under side of the scanner you will see a green latch about an inch and a half long and half inch wide.
Turn the machine off. push the scanner latch inward , then pull it back toward yourself until you hear and feel it snap into place. Then turn the machine back on. that should do it.
Nov 18, 2008 | Xerox CopyCentre C20 Black and White...
Scanner locked on my xerox 2218
Its easy to fix. Turn the machine off, then look in the area where the copies comeout. Where you reach your hand in to remove the copies or received faxs. Squat down and look on the inderside of the scanner in that area. You will see ONE green item, it is the scan lock. It's about an inch and a half long and about a half inch wide. Shove it in, toward the back of the machine, then pull it out toward you until it snaps back. It may be a bit tight and may require a pretty decent pull back.
Once you snap it toward you, turn the machine back on and it should be ready to go.
Oct 23, 2008 | Xerox FAXCENTRE 2218 18PPM FAX
23 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
