LEFT FRONT==WHT/BLK-NEGATIVE
LEFT FRONT==WHT=POSITIVE
RIGHT FRONT==GRAY/BLK=NEGATIVE
RIGHT FRONT==GRAY=POSITIVE
RIGHT REAR==VIOLET/BLK=NEGATIVE
RIGHT REAR==VIOLET=POSITISVE
LEFT REAR==GREEN/BLK=NEGATIVE
LEFT REAR==GREEN=POSITIVE
YOU NEED THE CONNECT A HI/LO LEVEL TO THE REAR SPEAKER WIRES TO THE REAR SPEAKER WIRES TO GET SIGNAL TO THE AMP;;
SOURCE: Install two 10" subwoofers in a 2002 grand am monsoon.
The only way to Correctly do this is to Run an External Amp for your Subs. If you continuously run the Subs off of the Factory Amp It will Ruin the Subs and the Amp Eventually. This way you can still Connect the Rear speakers as they need to be. Please Rate my solution, I need all the Help that I can Get! Thanks!
SOURCE: DXZ545MP rcas to sub amp
Blue white is remote to amp.... Grey and black are your RCA out to amp...
SOURCE: Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
SOURCE: need wiring color code for power &speaker
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
