What manufacturer and model washer is it, please?
Testimonial: "Simpson 9.5 kg eziset"
I searched the internet using Google.com and could not locate a solution. I am unfamiliar with that make and model, and it appears to have been sold in Australia. Only one web site from several years ago mentioned a control board wiring problem but not how to repair it. That sounds like a decision whether to pay for a a repair or purchase a new machine.
https://www.productreview.com.au/listing...
A different make and model with E91 has this repair suggestion:
https://www.youtube.com/watch?v=UYjwN2Rx...
The youtube video posts the following steps:
Unplug the washing machine.
Check the wiring harness connections between the control board and the user interface board.
Reconnect any loose wire connections or replace the wire harness if damaged.
If the wire harness connections are good, replace the user interface board. If the problem continues, replace the main electronic control board.
Hi bsful1 - Typically, E91 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
Hello - Typically error code E91 on Frigidaire washer indicates a communication error with the user interface to main control board. A certified technician will need to check the wiring between both parts. Either part could be defective or unit may possibly have faulty wiring. Depending on the diagnostic either or will need replacing.
Hi Angelia,
E91 means that there is a communication problem with the user interface to main control board. You will need a certified professional to check the wiring between the main control board and the user interface board to determine which part has to be replace.
