Question about Maytag Washing Machines
Our maytag 5000 steam washer is giving a suds then an f35 code... please help
SOURCE:
TheMobilian
  • 8220 Answers
SOURCE: Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 02, 2010
SOURCE: Sud and F35 error in my kenmore elite h5 steam
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Posted on Aug 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore Elite he5t steam washer gets F35 error code
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Posted on Sep 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: suds then f35 Whirlpool Duet 4.0 Cu. Ft. 14-Cycle
Posted on Sep 30, 2010
Testimonial: "Fantastic. Like the subtle hint;)... and well deserved."
SOURCE: My Maytag 5000 front leader
We had the same exact problem. Service tech came out and diagnosed bad pressure switch, Part # W1015652. Swapped it for a $135 new one and it seems to work just fine now.
This would have been an easy fix for me to make had I known what to look for. Unplug and shut water, remove top cover, follow small diameter (1/4"?) black tube up from wash drum to where it plugs into the plastic pressure switch housing. Remove switch from its bracket, unplug wire harness and black tube, and replace.
Service tech said that this is due to using too much detergent, suds will creep up into the pressure tube from the wash drum and get into the small circuit board inside the pressure switch housing. He also recommended against using Kirkland Signature brand detergent even though it has the HE emblem on it. Best to use one of the major brands and only 1 to 1.5 tablespoons at most.
A google search for "Maytag 5000" reveals that this is a major problem because it is the 5th search result. "Maytag 5000 problems" search shows that this is the #1 problem with these washers.
Posted on Jan 03, 2011
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Whirlpool duet steam WFW9600TW00 code F35
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite 5t steam f35 and sud problem
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Maytag front load Washer Model MHWE500VW10 (5000 Series) . The dreaded F35 / SUD error code keeps coming up. I have checked the tubing and electrical connections to the Water Level Pressure...
Hi
There is only one Analog Pressure Sensor Switch Part no. W10156252, another one that it has is the water level switch (part no W10415587). I believe you are talking about the first one as that is what error code F35 means (ANALOG PRESSURE SENSOR FAILURE). Hope this helps...please post back for further assistance.
Daniel
Sep 17, 2011 | Maytag MAH21PDD Commercial Front-Load...
I get a "SUD" and
Kevin
May 12, 2011 | Washing Machines
Suds then f35 Whirlpool Duet 4.0 Cu. Ft. 14-Cycle Steam Washer - White
Sep 29, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Has code F35
I just got the same error code F35 and sometimes it says SUD. Help pls Kenmore HE5 Steam Washer.
Nov 14, 2009 | Kenmore Elite 45986 Front Load Washer
F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
Washing Machines Logo
55 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
