Question about Janome Sewing Machines
Looking for Janome MB4 technical manual. with full details on how to completely strip down mackbine
5 Suggested Answers
SOURCE:
  • 323 Answers
SOURCE: janome mb4
Loud chirping noises indicate a need for lubrication or something is rubbing against your carriage.
sewman7
Posted on May 19, 2008
  • 1564 Answers
SOURCE: janome mb4 restarts in different place after stop to replace broken needle
My machine is a bit different than yours but there is a way to back up your Janome 10 stitches at a time. Here is a thread that I initiated at the janome embroidery forum that should help you. Digimad included a detailed help for me. It should direct you to get you going again. Do join the forum the gals there are generally a great bunch and very helpful.
http://content.janome.com/fusetalk/forum/messageview.cfm?catid=7&threadid=4317
Posted on Aug 25, 2012
99rannellis
  • 12730 Answers
SOURCE: why does my Janome mb4 keeps shredding its top thread?
Change your needle and if it continues to happen, change the thread. Most likely your needle and thread are not compatible, ie the thread is too large for the needle's eye. Also, inexpensive thread will shred.
Posted on Sep 06, 2015
Why does my Janome mb4 keeps shredding its top thread?
Sep 05, 2015 | Janome MB4 Four Needle Embroidery Machine
My janome mb4 won'tt open designs I send from my computer. I have had machine for a year and never had this problem
Make sure you r sending design in correct format from memory mb4 reads only .jef format
Jan 20, 2015 | Janome Sewing Machines
Tengo problemas con maquina de bordar janome mb4, me distorciona el bordado. I have problems with mb4 janome embroidery machine, embroidery distorts.
If your embroidery is distorted be sure you are using the right stabilizer for the fabric you are doing the embroidery on and enough for the density of the design.
I hope that helps.
Dec 04, 2014 | Janome MB4 Four Needle Embroidery Machine
Janome mb4
are you using a good thread and the same thread on the top and in the bobbin, different threads will sometimes act up. I also can not sew one brand of thread on my machine, try Mettler or gutermann's you can get them at JoAnn's or Fabricland. hope it helps good luck K
Sep 23, 2017 | Janome MB4 Four Needle Embroidery Machine
Why does my Janome MB4 Jump in mid pattern and finishe 1" up or down?
This is usually caused by the y axis movement system. Occasionally this system can come out of sync, and cause the issue you described. Your y axis pulse motor may be going bad as well. In either case it would be best to take your machine to a Janome dealer for repair.
May 04, 2014 | Janome MB4 Four Needle Embroidery Machine
Janometroubleshooting
checks that the strip wire and strip wire sensor, this worked well.
(the strip threads is the small spring by which you spend the thread to thread)
Jan 04, 2014 | Janome MB4 Four Needle Embroidery Machine
Janome mb4 restarts in different place after stop to replace broken needle
Aug 19, 2012 | Janome Sewing Machines
Sewing Machines Logo
24 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
