Question about Garmin Boating
My boat has a complete Garmin Network: 2 MFD, AP, Radar, AIS, ETC. all working through NEMA 2000. I have a GMI 10 Display Will it require an adapter or read the AP through the network
SOURCE:
  • 196 Answers
SOURCE: Connection Issues Occur When I Try to Connect Through a Broadband Network Adapter
To resolve this issue, remove the network bridge. To do so, follow these steps: 1. Click Start, and then click My Network Places. 2. In the left pane, click View Network Connections. 3. Look for any connection that is bridged. 4. Right-click the bridged connection, and then click Remove From Bridge. 5. Repeat step 4 for each connection that is connected with a bridge. 6. When the bridge is removed from each network adapter, right-click Network Bridge, and then click Delete. 7. Click OK. When the all the bridged connections and the network bridge are removed, the broadband hardware is automatically detected.
Posted on Feb 16, 2006
Rubec
  • 42 Answers
SOURCE: dlink 2100 ap
If you default the unit, does it still reboot?
If so, it looks like the unit is faultly.
If not, you might have a IP conflict, or channel problem. Check the two units are on the same channel, but have differant IP address.
Posted on May 09, 2008
marcelbakker
  • 174 Answers
SOURCE: Display won't come up anymore
The power switch usually allows you to adjust the backlight with a short tap there should be a scroll bar, use the four way toggle up to increase the back light.
Posted on Jun 16, 2008
  • 57 Answers
SOURCE: broadcom network adapter has code 10
Try to update its drivers. Go to the Device Manager. In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
How to go to Device Manager:
1. Right-click on My Computer on the desktop and then click on Properties. Then click on the Hardware tab and then Device Manager button.
2. Double-click on Network Adapter. Double-click on your network adapter to view its properties.
3. Look for the Device Status or any error message. If it says "This device is working properly" then the adapter is properly installed.
Posted on Jul 22, 2009
  • 7 Answers
SOURCE: AP Wireless Network issue with MC9060
TRY TO UPGRADE THE AP FIRMWARE
Posted on Dec 22, 2009
Need to reconnect a c-80 system. I think the MFD, radar, GPS, and depthsounder are connected via Seatalk
I think your best bet here would be to post your query on the Raymarine forum.
There are actual technicians over there to look after you.
http://forum.raymarine.com/
Hope this helps you out.
Aug 01, 2017 | Raymarine C80 GPS Receiver
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno radar
Your antenna seems to be mis alighned. Its ZERO point must be readjusted.
Aug 30, 2008 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Proxim ap 2000 11b/g cardbus driver free?
i dont now how to get my uther computer to use wifi on the proxim orinoco ap-2000 11 b/g hit can u help me
Oct 13, 2010 | Proxim ORiNOCO AP-2000 11b/g Kit 802.11g/b...
Integrating AIS, Radar, Autohelm 7000 and flux gate compass.
ActiSense makes a programmable multiplexer that should do this for you. It is called an ActiSense NDC4 USB. Not sure is the Standard requires a separate compass signal, but if not, and the Standard can use a standard 38000 baud AIS data stream, the NDC4 will work for you. 847-746-0100
http://www.blueheronmarine.com/Actisense-NDC-4-USB-NMEA-0183-Multiplexer-with-USB-Port-6334
Jan 30, 2010 | Standard Horizon Cpv550 Gps Chartplotter...
Garmin radar error code 8
check the battery, some error due to battery problems, and then rest it for a while and then test.
melnavz
Aug 05, 2008 | Garmin Boating
On the GPS Garmin the radar screen shows our boat turned the wrong way. How do you turn the boat around on screen?
My husband moved the boat slightly and it seemed to correct the radar screen somewhat. He is working on the whole boat at present so didn't want to take it completely for a drive down the river. If we have further problems we may call in or use the web site.
Thanks,
Farrar
Jun 23, 2009 | Garmin Gpsmap 4208 Network Bundle
Where do all the wiring go to on the garmin 400c
The rest of the wires are for interfacing (letting the unit 'talk') with other devices such as radar or GPS. These wires/colors are pretty standard and defined by NEMA (National Electrical Manufacturers Association). You need wiring diagrams for the devices to hook them up. For fun, see where 'nema' takes you with Google.
Jun 18, 2009 | Garmin Fishfinder 400c With Dual Beam...
My ais targets are out of line showing them out of the river
If the AIS targets are out compared with radar target then turn compass to superimpose radar on to AIS.
If the AIS info is out compared with chart then suspect GPS. This could be yours or theirs depending on how many targets are out and whether it consistantly in one direction.
Good luck
Mike
Dec 12, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Jun 16, 2008 | Garmin GPSMAP 172C GPS Receiver
Boating Logo
Top Garmin Boating Experts
Keith Love
Marvin
Marvin
Are you a Garmin Boating Expert? Answer questions, earn points and help others
