Question about The Video Cameras
I bought a new SD card for my DXG-580V HD camcorder but it says that memory is full. I tried the Format function on it but is just sits there with an hour glass icon. How do I resolve this?
  • The Master
  • 5,723 Answers
Firstly, is the card the correct size for the equipment ? Secondly, can you format it on your computer ?
Posted on Apr 14, 2019
SOURCE:
starcomp
  • 118 Answers
SOURCE: memory card
connect the card in memory card reader and got to mycomputer-->right click-->manage-->disk management. see weather you memory size is correct or not if its different right click the memory card and delete the partation then create a new partation
i was done this to my san disk memory card
Posted on Mar 07, 2008
SOURCE: Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
Posted on Apr 15, 2009
  • 34 Answers
SOURCE: memory cards wont format, says card is full
Is the write protection enabled on the cards?
Which size having the cards?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmwar
Posted on Jun 09, 2009
SOURCE: SD HD card won't format
This camera only works with standard SD cards with a max of 2 GB
Posted on Nov 14, 2010
heatman101
  • 43501 Answers
SOURCE: my camera always shoing memory
Make sure that the camera is set to record to the memory card... often the internal memory will only handle a couple of pictures...
If it still shows memory full then a ribbon cable has come loose inside the camers and it is not recognizing the memory or cards...
heatman101
Posted on Apr 23, 2011
I have a DXG 5B1 HD and need to replace the card. What specific card is compatable?
As per this page:
DXG USA DXG 5B1V HD DXG Sportster 1080p HD Underwater Camcorder
SD Card (Up to SDHC 16GB Class6)
This is probably one of the best you can buy:
SanDisk Ultra 16GB SDHC Class 6 Flash Memory Card Speed Up To 30MB SDSDH...
If you don't need 16GB, you can buy cheaper cards with less storage space.
Jan 29, 2015 | DXG 5B1V HD Sportster 1080p HD Underwater...
Card locked on DXG 535V HD CAMCORDER
Take the memory card out of your camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 28, 2011 | DXG DXG535VK HD 80 Megapixel 720p...
Sd card is locked
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
May 02, 2010 | DXG Technology DXG-580V High Definition...
I HAVE A DXG DIGITAL CAMERA. WHEN I HOOK UP THE CAMERA INTO THE VIDEO INPUT THE PICTURE IS ALL JUMPY & UNCLEAR
Here's my problem: I recently bought as in today a PNY Optima 16 GB SDHC Card for my DXG-566V camcorder. When I inserted the card into it's SD card slot (which I assure you I did correctly), and powered up the camcorder, the camcorder didn't recognize the SD card, as it was still running off of the camcorder memory! Now I know the camcorder is just fine becuase after that I inserted my PNY 8 GB SDHC Card and the camcorder recgonized the card.
Please help me out here!
Jan 12, 2010 | DXG Technology DXG-566V Camcorder
When I turn on my Jazz DV 152/ T20 it displays "Read card..." and then nothing happens...I have a 4GB SDHC card by SanDisk...both camera and card are new....is this a faulty camera or am I doing something...
Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.
SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
Jan 04, 2010 | Jazz DV152 Camcorder
I recently bought a SanDisk 4GB SDHC card for my DXG-572V. I put it in the camera, and I turned the power on. A screen comes up saying "Format Card?". I have tried selecting both "Yes" and "No", but...
Your problem is that you are trying to use an incompatible memory card.
The DXG-572V is not SDHC compliant and will only work with regular SD cards. In theory it's compatible up to 4GB but in practice there are few standard SD devices which work well with standard SD cards above 2GB.
Oct 19, 2009 | DXG Technology DXG-572V Digital Camera
Memory Full...always
You need as SD card.
It only comes with 32 MB of memeory.  That almost useless.    Get 2 0r 4 GB SD card.
May 10, 2009 | DXG Technology DXG-566V Camcorder
HD 720 does not seem to detect 4 gig SD memory card.
I think it will only take SD memory cards not a PNY.
Jan 12, 2008 | Aiptek A-HD 720P Flash Media Camcorder
DXG 4.0 MEGAPIXIE DIGITAL CAMERA
Is the card Full? Ceck for images and if there are any delete them. If no images - then check yyour manual for the FORMAT mode and format the card - Do Not Attempt to Format in your computer
May 31, 2007 | DXG Technology DXG-409 Digital Camera
Video Cameras Logo
32 people viewed this question
Top The Video Cameras Experts
Prudhvi Kumar
Level 1 Expert
D. E. Hev
Are you a The Video Camera Expert? Answer questions, earn points and help others
