SOURCE: Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
SOURCE: splicing the wiring from a kenwood excelon kdc-x589 unit to a jeep harness
For the Kenwood KDC-X589:
yellow - always on B+12 such as battery + terminal
red - switched B+12 such as ACC of IGN switch
black - body/chassis ground (- battery)
orange/white - dimmer control wire (car light control switch)
gold - to my knowldege no gold
brown - mute control from mobile phone
pink/blk - external amplifier control/trigger wire
blue/white - power control wire similar in function as the orange/white
blue/blk - to my knowldege no blue/blk
blue - motorized/power antenna
For the vehicle, pls postback info on year and make/model.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
you don't need all those wires . Just connect what you have and the gmos will simulate the rest
