Question about Watches
I watched a segment where Michael explained which three knives you really needed in your kitchen. Unfortunately I did not save it. Can you help me?
2 Suggested Answers
SOURCE:
SOURCE: i have a michael kors watch with three dials. one ...
Pull out the center dial. It has two stages when you pull- first is to adjust the day, second is to adjust the time.
Posted on Oct 10, 2011
How can i remove the back from a mk watch that has four screws
Tricky question here.
If the watch case is made of metal, you will have no problem finding a screwdriver in some electronics parts store.
But be careful!!, if your MK has got a policarbonate case you are in danger by doing it yourself.
May happen you damage the screws head , and then you have to buy a new (and really expensive) case for your beloved watch.
If this is your case, I'd rather took it to a Michael Kors watch shop to do the job. It can save you a lot of money.
Regards.
Michael Kors Watches MK
Jun 15, 2014 | Michael Kors Watches
I bought mk-5019 yesterday. I wore it for a couple of hours. Today I noticed it somehow started changing that golden colour on the bracelet, so i really don't like it now. It looks like it's a fake watch...
unfortunately, it can be. its not gold, only a finish. and if you have a chemical in your skin that reacts to the chemicals in the gold tone finish it can wear off very quickly. Do you also get that green around your finger from a fake ring? or black on your earlobe hole from earrings? return the watch to where it was bought.
Sep 18, 2013 | Michael Kors Ladies Watch [ Mk 5019 ]
Where can I buy this watch
I can sell my Michael kors watch mk5060 email me
Dec 18, 2012 | Michael Kors MK5060 Watch
My g shock is solar and it will go from fully charged to plinking on low and then the next day its back on showing high and all i have to do is hit receive and its back up and running. its about 3 years...
That sounds the same as car battery will do when it has a cell going bad. It's possible the battery has a defective segment, and will show a full charge for a while. It just doesn't have the capacity or amperage to run the watch properly. It could just need a reset on the Service Center equipment...or it could be a defective battery, even after only three years.
Aug 07, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
How do you remove the pin out of Starck and Fossil PH1100 watch?
Ok, so if you are like me then you probably thought removing the three tiny screws from either side of the strap, and cutting segments of the strap and re-screwing the clasps back was going to do it. Unfortunately one realises that the clasps do not slacken to let the rubber straps out even after the screws are off. The critical point is to get the side pins out which is no simple feat. Getting the pins out releases the clasps and the rubber strap.
To get the pins out, use a wire cutter to cut down a paper clip to a length of 1 .5 cms or so. Hold this with a pair of tweezers along the axis of the pins while you hammer down in the direction of the small arrow inscribed on the metal clasp. With persistence a part of the pin comes out from the other end and you can then pull it out completely with a pair of pliers.
Removing the two pins with release the ends of the rubber straps. cut away segments as required while trying on so that you dont cut too many. Make sure you cut the same number of segments on each side. I had to cut three from each side since I have very thin wrists.
Now put the rubber strap back hold the clasps in position and push the pin back in place. Put the screws back and you should be in business.
It sounds complicated but is quite simple if someone shows you how....which I hope I have been able to.
Sudipto, India
Sep 09, 2009 | Watches
Casio Pathfinder PAG-50 battery replacement
ensure all three of the springs are present
the 2 at the top confirm that the case is closed the on at the bottom sends the sound signal.
ensure the metal casing on the back of the movement is not touching the back. and check the movement is correctly seated
Mar 28, 2009 | Casio Watches
What to do with watch repair kit
Unless the watch back has notches on it, you want to look around the edge of the watch and find a little lip. When you find the lipp, use one of the knives and pry open the back. Take one of the tweezers and pull out the battery, you could also use one of those handy-dandy screwdrivers to pry out the battery. Put the new battery in laying exactly like the old one , then proceed to close the back, making sure that the little notch (on the INSIDE lip of the back case) lines up with the stem and crown (the part used for setting the watch) so not to break it. The back openers and the knives are just differant ways to opn the back of the watch. Sometimes watches have screws on the back that need to be taken off in order to open the back case. The case vise is to minumize the wear and tear on your hands. The tweezers are for taking out the battery. If you have anymore questions PLEASE feel free to contact me I will be glad to assist you further! Good Luck!!!
Aug 12, 2008 | Watches
Watches Logo
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
