Question about Sony Computers & Internet
Hi friend.Please i need your help.I am serviceman and i have a tv Sony model KDLex655.This tv dont start and led stand by is flashing 3 times.The power supply(APS-322)start all voltages Ok
The voltage of Backlight is in 156 VDC but this is very low. I bought a new Power supp but its the same thing. Thank you.
SOURCE:
  • 556 Answers
SOURCE: sony TV kv29LS60e - over voltage protection
it is power supply problem. your oscillator for switching ckt or switching output failure. if you are not tech person call him for help. it is not a major problem good luck.
Posted on Oct 08, 2007
bob_computer
  • 3153 Answers
SOURCE: Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Posted on Aug 11, 2009
  • 6 Answers
SOURCE: Tascam DM-24 power supply voltage (+5v) too low for stable...
power supply needs to be replaced
Posted on Aug 16, 2009
  • 18 Answers
SOURCE: http://pinouts.ru/Power/atx_v2_pinout.shtml
um what you want lol:?
Posted on Sep 07, 2009
SOURCE: I have replaced the power supply on my Acer Aspire
When you have this problem on this PC, do not replace the power supply or the motherboard until you have first tried pulling out the video card. When the video card fails it can cause the x1700 to not power up. Pull the video card and see if it will power up without it.
Posted on May 19, 2010
I have a Sony KDF-E50A10 and I replaced the lamp. But the stand by/power light blinks red 3 times and still no pic or volume or nothing. What could it be ?
Hi
I managed to locate a manual for your TV and also a Support page on the Sony website which identified your problem clearly on two entries ie "The STAND BY indicator on the front of the projection television flashes three times" and "The STAND BY indicator on the projection television flashes 3 times". I thought this was going to be easy having found these, but both led to a page that said "This solution is no longer available". Thank you Sony !!!!
I didn't give up here found a YouTube video which described your "3 flashes" and stated that the bulb needed replacement if this was seen. I understand that the model is not exactly as yours but I give the link below:
How to replace TV lamp
Please look at it carefully because it looks as if - if this is correct - that you may have replaced one faulty bulb with another faulty bulb. Other than this I can't find anything very helpful on the internet.
Good Luck and best wishes
Nov 10, 2014 | Televison & Video
STAND BY BLINKING LED 6 TIMES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. For more information go to http://electronicshelponline.blogspot.com/
Nov 23, 2013 | Sony KV-35S26 35" TV
Stand by timer on my trionron sony tv flashes no picture
May I know the exact model no. of your unit. You've mentioned that the led light flashes, please count how many times it flashes...
Mjsazon
Oct 21, 2011 | Sony Televison & Video
I have a Sony KP-51ws520. I cannot power on. says stand bye and blinks 9 times.PLEASE HELP it is only 5 years old and they says some of the parts are no longer available.
Those LED flashs are a fault indicator...First thing to do is to try a reset:
With the TV plugged in push and hold down the reset button on your remote then press the power button on the the TV and then release the reset button once the screen has come up.
9 blinks means, "Zero Crossing Detector" and the probable cause locations listed are "D6166 or D6114 is open
If you are handy you can replace D6301 diode and it fixed the problem. You can buy that diode at partstore.com for $3. good luck
If still no luck then this is going to require a serviceman.
Jan 28, 2010 | Sony KP-51WS520 51" Rear Projection...
2004 Sony 52" Wega dont turn onnthe stand by light stays flashing. This TV first started by taking long to turn on and now and then would turn off until one day it just didnt turn on and the standby button...
When that model Sony shuts down the LED starts blinking as you say but it is telling you something because it blinks a certain number of times and then pauses and repeats the number of blinks. Count the number and then I might be able to help you narrow down where the trouble is.
Jun 14, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony tv won't turn on, standby light just flashs.
pls tell us specific problem that how many times LED blinks along with model No. to help you better.
thank you for using fixya
Nov 01, 2008 | Televison & Video
SONY KV-25X5U, TURNS IT'S SELF OFF AND STAND -BY LIGHT FLASH'S?
The standby light should be flashing in a repeated count with a short pause between the counts. If you could post that count here, it will give us an indication of the circuit in which a problem was found and allow us to provide solutions.
Thanks,
Dan
Oct 10, 2008 | Televison & Video
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is drbonnyb@yahoo.com
Oct 31, 2007 | Sony KP-FX532M91 TV
Computers & Internet Logo
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
