SOURCE: johnson 4 stroke 115 hp will not start. fuel
Sounds like and injector problem to me. If it was a 2 stroke I'd tell you to pull the carbs and clean them ,but EFI is a whole different story. Most certaintly a fuel problem, most likely injector related, you'll most likely need to go see a marine mechanic with the proper equipment to analyze, rather than start replacing parts you may not need.
SOURCE: When i start my bakkie it starts but as soon as i give petrol it cuts out
Try moving the engine wiring harness around while it is idling does it stall? This could also be distributor related like a defective pick up coil.
