Operator's Manual - CRAFTSMAN
Sears
https://i.sears.com > mp-tc > prod_1977954512
PDF
WEEDWACKER GAS TRIMMER. R. Model No. 316.711192 ... 25 cc (1.52 cu. in.) 0.025 in. (0.635 mm) ... Always use the fresh fuel mix explained in your operator's manual.
Sears
https://i.sears.com > mp-tc > prod_1977959112
PDF
Operator's Manual. CRAFTSMAN. 2-Cycle. WEEDWACKER GAS TRIMMER. Model No. 316.711471. INCREDI-PULLMW/TH. UNBELIEVABLE STARTING EASEâ„¢. CAUTION: Before using this ...
Instruction Manual
Sears PartsDirect
https://c.searspartsdirect.com > doc
PDF
Jan 10, 2005 - For one year from the date of purchase, when this Craftsman DGas Powered. Weedwacker. Line Trimmer is maintained, lubricated, and tuned up ...
User manual Craftsman CMXGTAMD25SC (English
Manua.ls
https://www.manua.ls > not categorized > Craftsman
Manual. View the manual for the Craftsman CMXGTAMD25SC here, for free. This manual comes under the category not categorized and has been rated by 3 people ...
Operator's Manual
Sears PartsDirect
PDF
Operator's Manual. M. 4-Cycle. WEEDWACKER® GAS TRIMMER. Model No. 316.794490. CAUTION: Before using this product, read this manual and follow all its Safety.
Craftsman WEEDWACKER 358.791520 Instruction Manual
ManualsLib
https://www.manualslib.com > manual > Craftsman-We...
View and Download Craftsman WEEDWACKER 358.791520 instruction manual online. 25cc/1.5 cu.in. 2-Cycle 17 Inch Cutting Path / 0.080 In. Line GASOLINE ...
Craftsman WEEDWACKER C944.514460 Instruction Manual
ManualsLib
View and Download Craftsman WEEDWACKER C944.514460 instruction manual online. 25cc / 1.5 cu.in. 2-Cycle 17 Inch Cutting Path / 0.080 In. Line GASOLINE ...
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
SOURCE: need gas line routs for a craftsman weed eater
The longer, (and sometimes smaller of the two), fuel line goes from the carburetor to the tank with the fuel filter attached to the end, inside the gas tank.The other line, ( sometimes larger), goes from the primer bulb to just inside the gas tank, about a 1/2 -1 inch inside with coupling attached to the end. Coupling keeps line from pulling out of tank.
Jim
SOURCE: troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
