SOURCE: generator not running smoothly under load
Hi
I think it is because the governor sistem.(no properly working).Perhaps the governor lever spring is tightened.There is a screw to adjust it,try to locate it.Hope this helps.
regards savumihai71
SOURCE: motor runs wide open but no power from generator
You will need to install new diodes,they are located in the plastic housing behind the receptacles...It looks like little spark plugs..They work to put dc voltage to the rotor,without the exciter voltage applied,you will not get ac power out..The part number is 3483.01....You can buy these online for about $6 each,they have 2 inside the generator,and you should change both.
SOURCE: how long does a timing belt last on a Hyundai Tuscon
Generally speaking most cars should have the timing belt changed every 60-80K miles just so that it doesn't break while your driving and do furthur damage. Most vehicles have the water pump changed at the same because they're in the same area and once you open it all up you just go ahead and change it all.
SOURCE: Honda eu2000 generator starts but no power to panel
You probably need to do a tune up. Change the spark plug, oil, air filter, and you may also need to add new fuel.
SOURCE: My Honda ES6500 watt generator keeps blowing 15 amp fuse
Hi there .
In my opinion you should remove the starter and check the starter first . After you remove the starter get a good 12v battery and 2 wires and test the starter . Make sure to not invert polarity . After you touch the wires on the contactor (small solenoid on the side) see if the overrunnig (part with gears) comes out easy and with no obstruction . If the overrunning does not come out you could have a bad contactor (part # 31204-ZA0-003) or a bad starter (part # 31200-ZA0-701) .
Hope this help
