Question about NorStar Lands Phones
We have a Norstar T7316E and we were trying to change how many rings before the answering service kicked in and now all calls go directly to the answering and not ring through. any suggestions
SOURCE:
  • 28 Answers
SOURCE: no ring,goes directly to voicemail
your phone is on 'do not disturb mode'. call your provider and ask how to shut it off. for telus mobility it is *79 then hit send
Posted on Sep 02, 2008
ynotphone
  • 192 Answers
SOURCE: Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Posted on Mar 20, 2009
ynotphone
  • 192 Answers
SOURCE: Need to turn off transfer callback on Norstar Meridian
Ok, well I can explain most of the programming template, but I cannot give you the exact buttons to push since each phone IS programmed differently.
-> first dial FEATURE 985 this will give you the DN(Extn) for the voicemail (record this number) and then RLS
-> now I need you to dial FEATURE 0 on your set, and press the Intercom key to ensure the extension of your set you want to change and then hit RLS.
To get into programming press FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will see 3 arrows on your LCD
<- Heading Enter->
<- Back Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Next (the bottom right arrow)
-> then you will see CAPABILITIES and press Enter. now you will see FWD NO ANSWER and press Enter, and put in the DN of the voicemail you saw with the Feature 985
-> hit Next for the number of rings you want to ring at the set before going to voicemail.
-> hit next and you can now RLS to back out of programming.
Voila, that set once called will now goto voicemail.
-OR-
You can get the receptionist to dial FEATURE 9 8 6 and the extension to transfer directly to someone's voicemail.
Posted on Apr 17, 2009
consultel1
  • 860 Answers
SOURCE: Norstar M7208 - Only 1 of 3 phones will ring
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Posted on Sep 21, 2009
consultel1
  • 860 Answers
SOURCE: How do you get a t7316e phone to ring
Programming2_bing.gif is done on M7310, M7324 and T7316 sets.
The display should say line 001: appear only
press the Chng key till it says appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
Posted on Dec 12, 2009
When I put my t7316E on "night" it only rings half ring then sends call to answer machine, Any way to change to a few rings so I can answer it if needed
That is generally how Night mode works - alerting you to a call then directing the caller to voicmail night message. You want to change the Forward No Answer setting in that mode; if your system doesn't support that, set FNA in regular (non-Night) for the attendant phone.
Oct 09, 2014 | Nortel T7316E 2-Line Corded Phone
I would like my phone to ring only when my extension is called.
Check you button programming by using Feature *0 and starting with the intercom button go up. If a button says "Answer xxxxxx", your phone is programmed to also answer that extension. This can be removed in programming by changing the Answer DN's down from Line Assignment. In this setting use the SCAN soft key to show the extensions assigned.
Mar 20, 2013 | NorStar T7316E Corded Phone
T7316E - Phones just installed. None of them ring.
You need to ensure that the main bell is programmed to ring, also that the extensions are also programmed to ring as well. Also check that the ringer is switched on, on the base of the telephones. Also ensure your handsets to not go over the ren value permitted. Make sure the service is on the correct day service and not night service. Check that the handsets ring internally and ensure they are registered with the system. Ensure that the connections and wiring are also correct,
Mar 15, 2013 | NorStar T7316E Telephone
Line one wont ring
Call a tech in, name change will not harm a line period.
Oct 09, 2012 | NorStar T7316E Corded Phone
Can I change the number of rings before the night
An AT&T specialist was able to help me over the phone
Nov 05, 2009 | NorStar T7316E Corded Phone
Hi - have a Norstar T7316E phone and cannot figure out how to turn the ring off when I'm on it.
If your telephone rings when you are on a call you will have to go into programming on the system and set DND on Busy to "Y" it will be set to "N" at the moment hence your phone rings when you are on a call, be carefull if your phone is the only phone to ring on incomming calls if you get a second call comming into system when you are on a call there will be no audiable ringing on any telephone to aleart you to this second i/c call.
Oct 01, 2009 | NorStar T7316E Telephone
Trying to switch the extension number.
On the newer norstar systems the T7208 and lower phones can not be used for programming.The T7316e phone has to be used for programming therefore feature 983 will only work on the T7316e set.To change local dn's you have to go into config programming and to change dn old dn then new dn.
Sep 29, 2009 | NorStar T7208 Corded Phone
NorStar T7316E Corded Phone - voicemail / ring time
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.press show then next.and change the ringing as per ur requirement.
Feb 23, 2009 | NorStar T7316E Corded Phone
Norstar T7316e
chang the call log options to none on the specific phone you want it to stop on. or you can go to feature settings and change the call log options to 0 system wide..
Mar 26, 2008 | NorStar T7316E Corded Phone
Change the amount of times it rings before goes to V-mail
In Coverage path form for voice mail
COVERAGE CRITERIA
Don't Answer? y y Number of Rings: 2
COVERAGE POINTS
Point1: h2 Rng: 1
you can change Number of rings,Rng options
Jan 17, 2008 | NorStar T7316E Corded Phone
Lands Phones Logo
35 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
