SOURCE: Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
SOURCE: Elna 7000 - Mislaid manual. How do i use program B (letters)?
Hi jennymalibu! The best thing for you to do would be to download a new manual (free) from the Elnal site. It's in a .pdf format, so you need to have Adobe Acrobat Reader installed on your computer (also free at Adobe.com) Below is a link to your manual. Just click on it, or if it doesn't work, copy and paste it into your browser window. Good Luck! Hope this helps! Hal http://elna.us/files/File/service_manuals/7000_service_manual.pdf
SOURCE: Can anyone tell me if the Elna 3007 sewing machine
Mechanical.
Here is an overview - http://www.oksewingandvacuum.com/3007.htm
Testimonial: "Thank you so much. It is mechanical, as I thought not computerized. There is going to be a very disappointed buyer on ebay!!!!"
SOURCE: My Elna 6005 Heirloom
When you switch sewing modes, what does the display read as far as the stitch type you are using?
SOURCE: My elna quilters dream machine has 84o test mode on display and I can't select other stitches
you might think about having the machine check to see if there is something wrong with the motherboard
