Question about KitchenAid Dishwashers
My Kitchenaid KDFE304DSS0 dishwasher keeps turning the child lock on. Otherwise it works fine, I just have to disengage the child lock before each wash. Any ideas?
SOURCE:
SOURCE: how do u get the washing machine of 'child lock?'
hold down start button for 3 seconds good luck!!!
Posted on Nov 20, 2007
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Have a kitchenaid dishwasher KUDS25SHWH1 - the
Unplug the unit for 15 minutes then plug it back in. This should reset all your computer system and make everything work again
Posted on May 28, 2009
SOURCE: KITCHENAID DISHWASHER KUDS25SHWH1 THE CHILD LOCK
press and hold the energy saver button until child lock light goes out
Posted on Nov 08, 2009
SOURCE: My KitchenAid dishwasher (KUDS25SH) start and stop
MY KUDI25 CHWH1 has the exact same problem...I'd love to hear about a fix!
Posted on Mar 01, 2010
My top drawer of kitchenaid dishwasher lock light is on. I can't get it off?
It's a child lock. To turn off the child lock on a Kitchen Aid dishwasher, locate the Energy Saver/Dry button. Press and hold this button for at least four seconds.
Jun 20, 2016 | KitchenAid Dishwashers
HOW DO YOU DISENGAGE THE CHILD SAFETY LOCK?
From Page 13 of the owner's manual
To turn Child Lock off
Press and hold ENERGY SAVER DRY for 4 seconds. The
light turns off.
Full manual available at the following link in PDF form
http://www.managemylife.com/mmh/lis_pdf/OWNM/L9050332.pdf
Sep 25, 2015 | KitchenAid Dishwashers
Child lock on. How do you get it off?
I went out on a service call for this dishwasher yesterday. The complaint was that the door latch was broken and the child lock light was lit. I temporarily rigged the latch to work until the replacement part came in but that left me with the problem of the child lock still engaged. The mini-manual for this dishwasher is located behind the kick plate. The mini-manual revealed that the child lock (called a control lock in the manual) can be disengaged by pressing and holding the air dry button for four seconds. So now the customer can run the dishwasher with the rigged door latch until I can properly repair it later this week.
Hope this works
Jan 30, 2012 | KitchenAid 24 in. KUDU02FR Built-in...
Child lock
If a button exists for the child lock... hold it down for a few seconds... it might disengage.... worth a shot.... without looking
Jan 16, 2012 | KitchenAid Dishwashers
The child lock is stuck on my kitchenaid superba dishwasher
Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Apr 03, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Child lock to turn off
Well you can please follow the below steps -
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Good Luck!!
Thanks
Mar 02, 2010 | KitchenAid Dishwashers
THE DISHWASHER WILL NOT START. THE
Check the manual and see how to disengage the child safety button. If you have already tried that and it has not worked, then you need a new Electronic control assembly. You did not give the model number for your dishwasher but they run from $86 to $146, depending on your model. This is an easy repair and can be done by anyone who is moderately handy. Remember to turn off the power to the dishwasher by removing the fuse or turning off the breaker before attempting any repair.
Feb 01, 2010 | KitchenAid Dishwashers
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
Dishwashers Logo
73 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
