Question about Radio Communications
Energy Sound Bar Elite: Randomly breaks squelch with loud bouts of crackling and static at a volume level higher than what was set. Any suggestions?
SOURCE:
SOURCE: static noise
Check for the Third earth wire of your computer else check for the motherboard taking earth for the cabinet.
Good luck
Posted on Oct 11, 2007
SOURCE: popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
Posted on Aug 14, 2008
SOURCE: NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
fooyun@sbcglobal.net
Posted on Aug 28, 2008
SOURCE: SoundDock produces only harsh crackling sound
Yeah i had that same problem. You know the chord? The cord you plug in from outlet. The square cord you plug into your speakers.. yeah the "DC outlet" is supposed to be UP. if you have it the wrong way in there it wont work and will make a crackling sound.
Posted on Dec 26, 2008
lsteward68
  • 333 Answers
SOURCE: crackling sound coming from speaker w/controls
are you sure this is not coming from the component and not the speakers? what head unit are you using
Posted on Jun 22, 2009
Why static on motorola CLS 1110?
Are you referring to static (random snapping, crackling, popping) that only occurs when you are handling the radio, or a steady hissing sound when turned on? The first may indicate the radio has a defect or loose internal connection; the second is reduced by adjusting the squelch setting. More information is always helpful.
Aug 01, 2014 | Motorola CLS 1110 (1 Channel) 2-Way Radio
My Ranger2950 has no sound??
Have a look here for info about the Ranger 2950. This is an Amateur 10 & 12 meter transceiver that enjoy some popularity due to its ability to be modified to work on the 27Mhz Citizens Band.
Make sure the Mode is set to something other than PA. A few of the first things that come to mind is the Volume, Squelch & RF Gain settings. The Volume is straight forward - choose a setting in the middle to begin. Next, set the squelch. Most radios have the squelch open when set fully counter-clockwise. As you move the squelch to this position, sound should be heard from the speaker if a signal is present. As long as there is an antenna connected, the radio should "hear" noise. If you do not hear anything, leave the Squelch fully CCW and try varying the RF Gain fully in one direction. If you still hear nothing, set the Squelch to the fully clock-wise position. Adjust the RF Gain to the opposite direction. At this point, you should have heard something - even if just static hash. If not, the volume control may be dirty. Disconnect power and rotate the volume control back and forth several times to dislodge any dirt on the volume wiper inside the radio, and try again.
Make sure that the Ext Spk jack does not have a plug inserted as it will defeat the internal speaker. Likewise, if using an external speaker, make sure it works.
Nov 19, 2012 | Ranger Radio Communications
How can i hear what they are saying without that awful loud sound when they arent saying anything. cause when i turn the volume down i cant hear what they are saying
Turn up your SQUELCH button when no one is talking until the static noise just goes away.
Now your set will remain quiet until someone talks.
If you set the squelch too high it will also cut out the people talking, so always try to have it set just slightly above the background static level.
Good luck.
Apr 15, 2011 | Uniden BC350C Base Scanner
I hooked up my Mackie MR5 Monitors to my MacBook Pro through an audio interface, I use it to record my band in the studio I use out of my basement. Except everytime I try to use the monitors they give me...
try hooking headphones to the output and see if the crackling is still there.
then, try it with the speakers, at a lower computer voume level and higher speaker volume level. perhaps the headphone output is too loud and distorting in the speaker inputs.
Nov 28, 2010 | Mackie MR5 MR5 Reference Monitor
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
How do i set my knobsso my radio works
Turn the volume up about 1/3, the squelch off or fully counterclockwise. You should now hear static or talking,if not something is wrong with the radio. As a last resort change to channel 19 and see if it is dead as well. None of this is valid unless you have a proper antenna connection. When you are receiving then adjust the volume to a comfortable level and turn the squelch up, clockwise, until it just mutes when no one is talking. The higher the squelch the stronger the signal has to be to be heard.
Good Luck,
Gilshultz
Dec 01, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
CHT12 speaker cuts out randomly have to turn off and on to get sound
Here is something you can try.
On your source check the output level for your sub.
Try setting up at a higher level, if at 1 set it for 2 or 3
Then adjust the volume control on the sub down to mach the speaker volume level.
Nov 25, 2009 | Velodyne CHT-12 Subwoofer
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Bose Lifestyle 35 Accoustimass module rattles at high volume
Well to be hones 85 sounds pretty loud to me, generally the bose acoustimass module shouldnt really be distorting or crackling unless under extremely high sound levels.
It could possibley be that the speaker cone in the bass module has a slight perforation so it would distort at high levels. However other problems could be loose connections inside the unt or outside the unit. If your friend doesnt have it above 85 under normal circumstances I wouldnt worry to much about it but if there is a tear in the cone the problem could get worse.
Nov 27, 2008 | Bose Acoustimass 15 System
Sound quality
Will not turn on get blue screen with eq band only after leaving it on for some time i get some function out of it only at low volume setting if i try to turn it up reception and sound quality breaks up
Oct 12, 2007 | Pioneer DEH-1500 CD Player
Radio Communications Logo
29 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
