Question about Cell Phones
How do i flash Tecno w3 that stuck? thanks
And how do i get software interface and the firmware to download on google?thanks
  • 5,317 Answers
Ask the oem maker, Tecno.... we are not them.
all we can do is point to the obvious. the OEM maker is Tecno.
google techno cell phone home.
Posted on Apr 12, 2019
2 Suggested Answers
SOURCE:
Buntydcmc
  • 121 Answers
SOURCE: I have a Nokia 7610 mobile phone. I want to flash
first download nokia pc suite and conect ur phone with this .
Posted on Nov 19, 2009
My cell fone xpressmusic 5220 is dead ad i want to flash or re-install software
Here is the procedure.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5220 file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment/Click here1. thanks for visiting fixya. Good luck.
Aug 30, 2011 | Nokia 5220 XpressMusic Cellular Phone
Tip
Firmware
Sorry for my English, I’m going to try to express what I want.
I found on Internet all the firmwares of this model, also a service manual, and the programmer software to upgrade the firmware of this TV, I have the American, Australian, Pal and European firmwares, but the problem is that I haven't the interface to connect my notebook with the TV, I know that I have to connect and RS232 port with a D-SUB 15 (VGA INPUT), the problem is how to construct this interface, I want a scheme to do it or if somebody know the pin outs of the D-SUB 15 connector to transmit data that’s will help a lot. I somebody want the firmwares files and the programmer software only ask me.
Thanks in advance
Oolong
on Jan 26, 2009 | Acer AL2671W 26 in. LCD Television
Where can i find firmware updates for LG GSA-4163B dual layer burner - believe it to be A106
You can download any available ODD (Optical Disc Drive) updates from http://us.lgservice.com. Click Product Support, click Optical, choose your model number from the list, and click go. Click the Drivers & Software tab. Download the latest version posted (highest number).
The firmware for all recent drives works with Windows. Before running the update, make sure the drive is empty. Close as many programs running the background as you can. Run the downloaded executable file to start the update. Some will automatically start updating the dive and some will require you to push "Upgrade" or "Start". If the firmware doesn't see the drive it was designed for, it will not install.
WARNING: Never update the firmware if the problem you're having is the drive isn't seen by windows, won't write with the included software, or other interface related problems. Unless the firmware specifically states it fixes the problem you are having, firmware updates normally don't fix these types of problems. Trying to update the firmware when there are interface problems can damage the drive's firmware. An error when updating the firmware is usually caused by a problem with the drive interface or there is more than one drive connected to that IDE channel.
IMPORTANT: do not interfere with the drive during the firmware update. If an error occurs during the upgrade process, or the upgrade process is cancelled during this process, damage to the drive can occur. If you experience any problems or have any questions, please contact our LG customer support line toll-free at 1-800-243-0000.
Hope this helps you
Aug 21, 2011 | LG (GSA4163B) DVD±RW Dual Layer...
I got the old 407291 software version on my machine and would like to upgrade my firmware, but LG says : Contact your dealer --- Please help
You can download any available ODD (Optical Disc Drive) updates from http://us.lgservice.com. Click Product Support, click Optical, choose your model number from the list, and click go. Click the Drivers & Software tab. Download the latest version posted (highest number).The firmware for all recent drives works with Windows. Before running the update, make sure the drive is empty. Close as many programs running the background as you can. Run the downloaded executable file to start the update. Some will automatically start updating the dive and some will require you to push "Upgrade" or "Start". If the firmware doesn't see the drive it was designed for, it will not install.
hope this helps
Aug 11, 2011 | LG BH08LS20 Blu-ray Burner
Need dvd rom drivers
If you are using Windows OS, most of the CD/DVD Rom drivers are generic you do not need to install any drivers for the devices to function. If it is the firmware that need updating, go to the manufacturer support to download the firmware file to update your DVD Rom firmware.
If your Windows system cannot detect your DVD Rom, it could be your DVD drive had failed. Is the DVD drive settings for set correctly ie. if your DVD drive is of IDE interface. No settings is required for SATA interface.
Hope it helps.
May 17, 2011 | Computers & Internet
Hi Thanks for taking the time to help if you can. My problem seems to be that I dont know what software to use to download the firmware update program for the router could you give me your suggestions...
You never need to use any software... just connect any one of your computer to the router using an ethernet cable and type http://192.168.2.1 in the internet explorer... It will open the belkin router interface...
On the far left hand side below the "Utilities" you will have an option called "firmware update"...if you look inside that option you will have an option to browse.... click on browse and locate the latest firmware file and update it... Thats it you are done...
The latest firmware has to be downloaded from belkkin support site...
Download the appropriate version of firmware from this link...
http://en-us-support.belkin.com/app/answers/detail/a_id/299
click here for instructions with screenshot...
http://en-us-support.belkin.com/app/answers/detail/a_id/497
Jan 12, 2011 | Belkin (F5D7230-4) Router (587009)
Rca lyra rd2840 firmware download
Check the follwing sites:
http://drivers.softpedia.com/get/FIRMWARE/Lyra/
http://www.drivers-software-download.org/tag-download-lyra/
http://www.downloadtube.com/Drivers/Firmware/Lyra/
By the way, the only I did just was Google the internet and look for "RD2840 firmware download"
Best regards,
Jun 27, 2009 | RCA Lyra RD2840 MP3 Player
How to upgrade firmware from 6.1x to 7.4x, and where to find it?
log in to belin website "www.belkin.com/uk/support and download the firmware under software and firmware section.
once u download it lof in to your router unterface by connecting the rtr to ur comp.
open the internet explorer and typr 192.168.2.1 and on the router interface u have firmware update clikc and browse te file u download and click update that r bye............
Dec 16, 2008 | Lucent Pipeline 130 Router
Thanks...820g drive
yes try to use powerISO or like daemon tools to install the firmware update
you can search it a google for the said software
Sep 24, 2008 | HP Media Center m7250n (ED842AA) PC...
Cell Phones Logo
54 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
