To program your remote to your Samsung HD 3500, follow these steps:
Turn on your Samsung HD 3500 and your TV.
Press and hold the "TV" button on your remote until all the mode buttons light up.
Enter the three-digit code for your TV using the number buttons on your remote. You can find the codes in the user manual for your remote or online.
Press the "#" button on your remote. The mode button you selected should blink twice to confirm the code was entered correctly.
Test the remote by pressing the "TV" button and seeing if the TV turns off. If it does not, repeat steps 3-4 with a different code until you find one that works.
If you cannot find a code that works for your TV, you can try the automatic code search method:
Press and release the "Power" button on your remote.
Press the "Up" button on your remote repeatedly until the TV turns off. This may take several presses.
Press the "#" button on your remote to save the code.
Your remote should now be programmed to your Samsung HD 3500.
Here are some general steps you can try to program your remote control:
Determine the brand and model of your remote control. This information should be available in the user manual or on the manufacturer's website.
Turn on your Samsung TV.
Press and hold the "Code Search" button on your remote control until the indicator light turns on.
Press the "TV" button on your remote control.
Enter the code for your Samsung TV. You can find a list of remote control codes in the user manual or on the manufacturer's website. Alternatively, you can try entering codes until you find one that works.
Press the "Power" button on your remote control. If the TV turns off, the code has been programmed successfully. If the TV does not turn off, repeat steps 3-5 with a different code.
If none of the codes work, it is possible that your remote control is not compatible with your Samsung TV. In this case, you may need to purchase a new remote control or contact Samsung customer support for further assistance.
Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...Guide to Programming the ... - Download the Manual - 8 Device Learning Jumbo ...
How to program a Samsung AK59-00104K remote control
How to program a Samsung AK59-00104K remote with codes:
Turn on the TV.
Point the remote at the TV.
Hold the "TV POWER" button while entering a two digit code.
Release the "TV POWER" button.
If you enter the correct two numbers, the TV should switch off.
TIP: Start entering the remote codes at 00, then 01, then 02, then 03, etc...
TIP: Once you find the correct code, write it down somewhere you can find it next year!
