Lands Phones Logo
A
Anonymous Posted on Apr 11, 2019
Setting time & date for uniden home phone exs9500 serial # 94028608
Level 3:
  • Uniden Master 6,688 Answers
  • Posted on Apr 12, 2019
Cindy  Wells
Uniden Master
Level 3:
Answers
6688
Questions
0
Helped
3530001
Points
21744
The directions to set the date and time on the Uniden EXS9500 are shown in the manual starting on page 21. Press and hold the Clock button (the second button from the left below the answering system buttons) on the base until you hear a beep. Use the Skip/Repeat buttons (the two end buttons of the answering system buttons) to select the current day of the week. The LCD with show 0 through 6 and the voice prompt will list the day of the week. Press Clock when the correct day of the week is announced. Use the Skip/Repeat buttons to select the current hour (1-12). Press Clock to set the hour. Use the Skip/Repeat buttons to select the current minutes and press Clock to save the setting. Use the Skip/Repeat buttons to select AM/PM and press Clock to save the current time and exit the clock setting menu.
ManualsLib has the directions starting here: https://www.manualslib.com/manual/334436/Uniden-Exs9500.html?page=21#manual .
I hope this helps.
5 Related Answers
A
Anonymous
  • Posted on Dec 26, 2007
SOURCE: Setting Time and Date on phones
Just got this phone. It is indeed day/month/year. European style. NOT what we want for a phone in the states. Really annoyed with the fact there is not an option. Might be returning it.
Tom Torre
  • 279 Answers
  • Posted on Sep 19, 2009
SOURCE: How do I set correct time on cordless uniden phone?
You will need the model #. Go to uniden.com and look in customer service/manuals. They may have it to download.
Rob C
  • 547 Answers
  • Posted on Jan 21, 2010
SOURCE: No dial tone. Cannot call/recieve.
Have you tried placing the handsets in the base unit to resync them? (not the axillary charger)
Have you confirmed that the phone jack and wire are still working? (e.g. plug in a known-good corded phone and make sure the signal is still good)
Post back with the "Add comment" button on the right, and we'll see what we can do to get it fixed.
Anonymous
  • Posted on Jul 22, 2010
SOURCE: How to set date on Uniden DSS2465 Cordless Phone?
my uniden dss2465 is giving a signal every 60secs
  • 102366 Answers
  • Posted on Dec 17, 2012
SOURCE: how do i set time and date on uniden dect 6.0
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
How to set time and date on uniden dect 6.0 answerin machine
Try posting in the Uniden group. Some phones get time/date from incominbg CallerID.
4helpful
How do I set the time and day on my Uniden hands free phone?
Press MENU/SELECT to bring up the menu. Use up/down to select "Date & Time" and press MENU/SELECT.
If you have caller ID, the first time a call comes in with the caller ID info, the phone will automatically set the date and time.
If you need a manual, you may download a copy here.
How do you set the date and time? how do you
Since you didn't specify the model of your Uniden DECT 6.0 phone, select it from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to get the manual.
2answers
Set time and date
Press the MENU/SELECT button to bring up the main menu. Full instructions are in the manual at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1680om.pdf
Caller ID date and time doesn't show up on cordless phones
Here is a link to the manual for the 756 series of Uniden phones.
http://www.uniden.com/pdf/DCT756om.pdf
You should just have to set the caller ID time and date. Hope this helps.
1helpful
Phones out of Range
If you start over and unplug the home base and then plug it back in and set the time and date etc, then re register all the handsets by placing them into the base for 10 seconds each, that should take care of the problem,,,Good Luck.
Blinking date and time on base of GE 27909EE1 Cordless Phone
Are you in a 'thick' building that may be preventing the phone from getting the date/time set signal? If so, try plugging the phone in as close to a window as possible to eliminate any possible interference.
5answers
Press 1 for English
Do you possibly have the phone set on Pulse dialing when your phone company only supports Tone (or vice-versa)? Hit Menu, select Global Setup, then Dial Mode, and see which is selected. Try the other and see if that fixes it.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
