Question about Sanyo Televison & Video
Out of range change HDMI input signal reso!ution.... Trying to connect a Sanyo bluray dvd to a sanyo tv
SOURCE:
  • 3600 Answers
SOURCE: Hooking Sanyo TV up to a computer
you need a hdtv tuner Hidef is different format than the rca jacks and digital won't worrk sorry.
Posted on May 24, 2009
  • 25 Answers
SOURCE: I connect my sanyo 42 inch LCD tv via s-video, no signal on TV
Be sure you changed the source on the tv (i'm guessing you did this), be sure you switch the out-put on your computer to s-video. You can do this in the properties box. If you are running the nvidia video utility, you can set up hot keys to do this. I set up ALT, Z, 3 as my hot key combination. All I do is hook up to my tv, press the three buttons above, at the same time, and the video moves from my pc monitor to the tv.
Posted on Sep 10, 2009
  • 290 Answers
SOURCE: connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Posted on Jan 02, 2010
  • 5870 Answers
SOURCE: Hi, When I connect my Samsung
I suspect that the TV can't read the signal from the computer on the HDMI port. You would get a signal from a VGA connection. (Computers send a slightly different signal over HDMI than a DVD or blu-ray player.)
In general, when connecting a TV to a computer, turn off both devices before connecting the video cables. Then turn on the TV and set it to the source (with the no signal message). Then turn on the computer. Next set the computer to output the video on the external video port. (Depending on the laptop, you may need to enable the port in the BIOS. To access the BIOS, press Esc, F1, F2 or F10 repeatedly as you turn on the computer. The key depends on the brand of computer.) Next set the video output in the OS (depends on the OS). For Windows 7, right click on the desktop (anywhere there are no icons or running programs), select Graphics Properties and set the desired monitor choice (laptop monitor, external monitor, both or extended). Click Apply and then confirm this when the display changes. (At least this works for my HP laptop on the VGA port.; my desktop lets me change monitors under Screen Resolution.)
The manual for the TV is available here: http://www.sanyo.com.au/resources/manuals/tvs/lcd42xr9da_im.pdf .
I wish that I had better news for you.
Posted on Apr 22, 2011
simplemitch
  • 752 Answers
SOURCE: DVD input to HDMI 1 have no signal (displayed by
Some Onkyo receivers are known to have HDMI issues (it has faulty capacitors). The first thing to do is to reset the receiver.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button (see page 96 of the manual).
If that doesn't work it will have to go in for repair to have the HDMI board replaced.
Posted on Jul 11, 2011
No to hook sound bar to element TV and my DVD player at the same time
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and... The soundbar has an optical cable option, but my tv does not support that cable. ...SolvedHow do I connect my Element ELEFW392 TV to my Insignia ...
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... first time, that paired the sound bar to the subwoofer but still no sound. ... Do I have to connect sound bar to TV AND Dish receiver? and not to DVD?
Jan 11, 2016 | Sanyo Televison & Video
I need to change the tv to HDMI
A puzzling question Seth
To change a television to HDMI, you just scroll through the Input choices using the remote until you get to the HDMI socket the 'signal' is connected to.
The TV is Sanyo? Why do you need a Phillips remote? Why do you have to format the television?
Direct TV is your television signal supplier which doesn't have a lot to do with anything :>) The box has an HDMI socket? You connect an HDMI cable to the HDMI socket on the television and I refer you to my first paragraph.
Dec 11, 2015 | Televison & Video
I'm trying to get my DVD player to show up on the TV, but the screen says no signal. I think my connections are fine.
you have to switch the input to whatever you have them connected with either avi , hdmi
Aug 30, 2015 | Sanyo DP26649 26 in. TV
What does that mean if its saying out of range change HDMI input signal resolution
Your TV is trying to read the signal on the HDMI socket, and it's not strong enough to work, perhaps the cable is too long. It's suggesting you lower the resolution of the signal at the sending system.
Oct 12, 2014 | Sanyo Televison & Video
I just bought a phillips blu ray and trying to hook it up to my sanyo 50" plasma through a hdmi i get video but no sound the tv says to use the dvi port and audio 3 inputs but the blu ray does not hav
Hello there, the hdmi cable is a great way to get high definition video from a bluray player to a tv, but if the bluray player is part of a surround sound system you will need to get the sound to the tv separately. There is often a red and white audio terminal in the rear of the bluray player, sometimes located next to a yellow terminal, these are known as a component connection as each component (coloured terminal) is separate and operates a separate function, but all 3 connections can be used together to create a SCART equivalent. You may need to connect an 'Audio Component to 3.5mm jack' cable from the white and red terminals to the headphone/line in socket on the tv.
alternatively, as wilth my player, there is a button on the remote which switches the audio source from component, hdmi, SCART, etc, this may be the same for you.
hope this helps.
Mar 12, 2014 | Televison & Video
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
The screen is black and a little box that says no signal is moving around on the screen
Check your inputs. The no signal box means exactly that - there's no incoming signal for the TV to decode. So you've either disconnected a cable somewhere or turned off your input device.
Try changing the inputs on the TV (this will be a button saying input or A/V)
Try changing the channels
Check that your cables are correctly connected and that whatever you are trying to use (dvd player, PS3, etc) is turned on.
Check that your TV is tuned to the corresponding input it is plugged in to (if you plugged your DVD player into HDMI input 8, tune your TV to input 8)
Hope this helps.
May 11, 2011 | Sanyo Televison & Video
How to tune in for blu ray dvd
You do not tune in your Bluray player but connect using an HDMI cable or Composite cable. If you have a HDMI cable connect the Bluray's HDMI out to the TV's HDMI in at the back and using the TV's remote switch the Input source to HDMI. You will see the image from the Bluray player in high definition.
If you don not have a HDMI cable connect the composite out of the Bluray player using the Yellow/Red/White cable to the TV's composite input ( same three color sockets ) and switch to AV input on the TV. Using this connection won't give you high definition image but will work OK.
Apr 23, 2011 | Sanyo DP32746 32 in. LCD Television
I have a Sanyo Cinema Progressive DVD player and the videos are playing back in black and white, rather than in color. What is the problem?
The output signal maybe set to S-video and the input connector does not have S-video capability. Change the output signal or use a HDMI cable. If the connection is via progressive cable (three leads), the colors maybe mismatched.
Apr 09, 2011 | Sanyo Cinematic Progressive Scan DVD...
I do not know how to work the display resolution
The tv display resolution will automatically change depends on your source/device output resolution and TV inputs used as well. Television component and HDMI inputs accept 480i up to 1080p signal while composite and s-video accepts 480i(lowest resolution) signals only. You will get high resolution signals from cablebox, game consoles, bluray etc through their component or HDMI output jacks.
Dec 25, 2009 | Sanyo DP50747 50 in. Plasma TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
