SOURCE: QUICK LINKS
Someone else has posted this same issue. I would contact the software vendor because if more than one person is having the problem, it's more than likely a problem with their software and not something on your PC. Most software sites also have a forum or FAQ where you can troubleshoot common problems.
SOURCE: headset setup
http://www.plantronics.com/north_america/en_US/products/cat1150057/cat1150057/prod5560012?prodfind=true&mftr=MOTOROLA Go to this website, and scroll down to Interactive Bluetooth Pairing Guide. (Plantronics 330 - V555 doesn't show 320 and instructions will be similiar). Click on Interactive Bluetooth Pairing Guide and a tutorial will walk you through the steps. Have headset and phone together when you do this and both must be charged. Hope this was helpful. Pam
SOURCE: setting up voip on nec ipk2 phone systems?
The easiest way is to set up a different extn number range for the sites, then in the system settings in the number scheme you programme the system with the ip address of the distant end against the extensions. Obviously you need a VPN between sites but it works really well as we have a number of installations like this
regards
SOURCE: unable to pair bluetooth headset to cell phone
After you have found the device trying enter 0000 as your password and you should now be connected.
SOURCE: lost installation cd for d link DIR 300 wireless G router
Most routers don't require discs and the disc usually contains mere documentation for configuration and help. Routers are usually plug-and-play type devices but if you're definitely wanting some type of program or information. You can visit the below link for your router.
http://www.dlink.com/products/support.asp?pid=474&sec=0#applications
You'll need to specify by clicking the "Click Here" based on the revision of your router (A, B, or D). Once you've selected a revision, you'll be able to download the application and firmware updates for your router.
